When using SOLIDWORKS, you may need to export your models as STEP files. This is often done when sharing projects with someone running a different version of SOLIDWORKS or when transferring data to another CAD platform. The two main STEP file options available are STEP AP203 and STEP AP214. In this blog, we will look at the differences between the two options.
A STEP file is a standardized, 3D CAD format used for exchanging 3D models across different software platforms, storing product design data such as precise geometry, colors, material properties, and even manufacturing information. Unlike mesh formats like STL, STEP files define solid, editable geometry, making them ideal for mechanical design, collaboration, and process planning, but they are not directly compatible with all 3D printing slicers without conversion.
STEP AP203 is primarily used for exchanging fundamental 3D model data. It captures the core elements of a design, including geometry and topology, making it well-suited for simple parts and assemblies where extra visual details aren’t required.
STEP AP214 expands on the features of AP203 by incorporating support for richer and more detailed data. It’s particularly useful for models that need enhanced visual and dimensional information, making it well-suited for complex assemblies and highly detailed components.
When choosing between AP203 and AP214, the decision depends on the level of detail your project requires. For simple data exchange focused only on geometry, AP203 is typically sufficient. On the other hand, if your work involves complex assemblies that demand richer visual and dimensional details, AP214 is the more appropriate format.
By recognizing these distinctions, you can export STEP files that align with your project’s needs and ensure seamless collaboration across engineering and manufacturing teams.
Want to learn more? Check out more SOLIDWORKS tips and tricks listed below. Additionally, join the GoEngineer Community to create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
Automatic Unit Conversion in SOLIDWORKS File Properties
Exploded Views for SOLIDWORKS Multibody Parts
Create Custom Weldment Profiles in SOLIDWORKS
About Zach Brown
