Create ODBC Connection Manually for SOLIDWORKS PDM
Article by Enrico Tolentino on Nov 24, 2021
How to Create an ODBC connection
There can be issues with SOLIDWORKS PDM databases hosted on an SQL Server named instance, where the client machines are unable to log into a local view or administration client. This is likely because the ODBC connection failed due to the client machine being unable to determine the correct dynamic TCP port used to connect the named instance of SQL.
To create an ODBC connection manually, we will use the Windows Administrative Tools. We will need to use both 32-bit and 64-bit Data Sources.
We will create the connection in the System DSN tab, click Add…, choose SQL Server, and then click Finish.
ODBC Data Source Administrator
Enter a name. We typically recommend the Vault name we are connecting to. The SQL Server and instance can be entered manually or from the dropdown menu. Click Next.
Create a New Data Source to SQL Server
Select With SQL Server authentication using a login ID and password entered by the user and enter the SQL login ID and password (default login is SA).
Click Client Configuration...
ODBC Connection Client Configuration
Deselect Dynamically determine port (the default port for Database traffic is 1433) and click OK.
Manual ODBC Connection Dynamically Determine Port Option
Check the checkbox for Change the default database to and select the SQL vault database from the dropdown menu we want to connect to and click Next.
SOLIDWORKS PDM ODBC Connection
The default selections can be left at this window. Click Finish.
ODBC Default Selections
This window shows the configuration of the ODBC connection that will be created. Click Test Data Source...
OBDC Test Data Source
The test results will be shown in the next window. Click OK.
SQL Server ODBC Data Source Test
Back in the ODBC Setup window, click OK to create the manual connection.
ODBC Setup Window
This will need to be repeated for the 64-bit connection as well. This will resolve issues where the client machine can’t log in to a local view or the administration client by creating a manual ODBC connection to the SQL servers named instance.
More SOLIDWORKS PDM Tutorials
SOLIDWORKS 2022 Data Management: PDM, Manage, & Admin
Top Mistakes Made Moving SOLIDWORKS PDM Server Components
Advanced Automatic SQL Backup - SOLIDWORKS PDM Standard
SOLIDWORKS PDM - How to Reset the SQL ‘sa’ User Password
Querying SOLIDWORKS PDM Database: Read-Only SQL User
About Enrico Tolentino
Enrico graduated from California State Polytechnic University with a degree in Engineering. He is a data management specialist at GoEngineer based in Southern California. A car guy, Enrico frequents the SoCal open track days to test his limits. And, of course, his corgi's name is Rally. :)
View all posts by Enrico Tolentino
