SOLIDWORKS PDM: Connecting to the SNL Server
Article by GoEngineer on Jun 15, 2015
Starting with 2015, SOLIDWORKS PDM uses the SolidNetWork License (SNL) Server to handle PDM licenses, just like SOLIDWORKS network licenses. As a result, companies must install the SNL server when they upgrade to PDM 2015 or later. Because it is a first-time installation of the SNL server, connection problems can pop up once the upgrade is complete.
If you perform an upgrade of SOLIDWORKS PDM from 2014 or earlier and you find that your client computers can’t access the license server even though your licenses have been activated, the problem is likely due to ports in the Windows Firewall that need to be opened. Read on.
In a typical environment, Windows Firewall is active on the server and may also be active on the client computer as well. The SNL server needs to communicate with each PDM client using two ports, typically 25374 and 25375. In both cases, the protocol is TCP.
To ensure that this communication can take place, connection Rules (sometimes called ‘Exceptions’) must be made in the Firewalls. Perform the following step starting with the server first, then do the same on each user machine where the Firewall is active. Here’s a step-by-step using Windows 7:
  1. Open the Control Panel app and select Windows Firewall
  2. From the left side panel, choose Advanced Settings
  3. In the Windows Firewall with Advanced Security dialog:
    1. From the left side panel, select Inbound Rules
    2. From the right-side panel, select New Rule
      Windows Firewall Advanced Security Dialog for Inbound Rules
  4. For the Rule Type step, choose Port, and click Next
    SOLIDWORKS PDM New Inbound Rule Wizard SNL Server
  5. For the Protocol and Ports step, choose TCP, choose Specific local ports, and type in “25734, 25735”, omitting the quotes, then click Next
    New Inbound Rule Wizard SOLIDWORKS PDM TCP Option
  6. For the Action step, choose to Allow the connection
    Connecting SNL Server SOLIDWORKS PDM Allow Connection
  7. For the Profile step, check all three options (Domain, Private and Public)
  8. For the Name step, enter a name that will be shown in the Rules list (ie, SNL Ports). Optionally, enter a description of the rule to further document its purpose, and click Finish
    SOLIDWORKS PDM SNL License Server Ports
  9. The newly created rule appears in the list of Inbound Rules
    SOLIDWORKS PDM Inbound Rules SNL License Server Ports
  10. Now, to create the same rule in the Outbound Rules, select Outbound Rules and click on New Rule
    SOLIDWORKS PDM Outbound Rules
  11. Repeat Steps 4 – 8 to create the new Outbound rule.
Opening the ports in this way should allow each PDM client computer to successfully communicate with the PDM server.
Learn More about SOLIDWORKS PDM
Option File - A Great Solution For Managing Your SNL(s)
Changing SOLIDWORKS PDM License Types
Moving the SOLIDWORKS PDM Archive Server Yourself? Start Here
SOLIDWORKS PDM Professional SQL Server Changes for 2022
