Exporting Derived Outputs from the 3DEXPERIENCE Platform
 Article by Randy Simmons on Oct 28, 2025
Derived Outputs on the 3DEXPERIENCE platform are PDFs, DXFs, STEP files, etc., that are manually or automatically created from your CAD files for use downstream. This article explains how to “package” these outputs and export them from the platform to send to someone outside of the company.
Note: SOLIDWORKS provides general information about Derived Outputs in its help documents. Please reach out to Tech Support or our implementation team if you need help with any of the setup for Derived Outputs.
There are a couple of methods and apps for doing this, each with pros and cons depending on the number of files and other factors.
Using the Product Explorer App
Method 1 - Using Product Explorer
Open the assembly that contains some Derived Outputs associated with it.
Using 3DEXPERIENCE Product Explorer App
Select the top-level node of the assembly (will highlight blue), then hit the information (i) icon on the lower toolbar.
3DEXPERIENCE Product Explorer Information Icon
This will open a side panel.
Navigate through the icons/tabs at the top of the information pane to Derived Formats.
3DEXPERIENCE Information Pane Derived Formats
Select the Download All Derived Outputs button.
Download All Derived Outputs Button in 3DEXPERIENCE
Set the options for what 3D outputs you want to collect (if any) and what 2D outputs you want to collect.
Give the .zip file a name and click the Download button.
Download Derived Outputs Dialog in 3DEXPERIENCE
If you have inserted multiple assemblies into Product Explorer, you must select each one individually and use the Download All Derived Outputs button.
The downside to this method is that it can only do one assembly at a time.
Method 2 - Using Product Explorer
Add an assembly, multiple assemblies, or even just random parts to Product Explorer, then use the checkboxes or SHIFT+select in the list to select them all.
Using the 3DEXPERIENCE Product Explorer
On the toolbar at the bottom, use Export As.
3DEXPERIENCE Product Explorer Export As Button
Name the file, choose to Expand All, and set the Derived Format Options as desired. Then, hit Export.
3DEXPERIENCE Export As Derived Format Options
A job will start.
When it is finished, a notification will appear in the upper-right corner of the platform.
Export Finished Message in 3DEXPERIENCE Product Explorer
Click on the notification bell icon and click the task that was completed.
3DEXPERIENCE 3DNotification Center
This will take you to the CAD Data Processor Monitoring app.
On the far right, click the Download button to download the .zip file.
3DEXPERIENCE CAD Data Processor Monitoring App
As mentioned, the .zip will contain all the CAD files as well. Just open the .zip in Windows Explorer, sort by type, and delete any unwanted files.
The downside to this method is that you will need to delete the CAD files from the resulting .zip files to only have the Derived Outputs left.
However, the upside is that you can do multiple assemblies at once or many unrelated files if needed.
Using Bookmark Editor App
Method 1 - Using Bookmark Editor
Find the assembly you want in an existing bookmark or add it to a new bookmark.
Right-click the assembly and choose Information.
Using the Bookmark Editor App in 3DEXPERIENCE
This will open a standalone window on top of the bookmark editor.
Navigate to the Derived Outputs icon/tab and use the Download All Derived Outputs button (same as in the Product Explorer method above).
Download All Derived Outputs in 3DEXPERIENCE
Method 2 - Using Bookmark Editor
This method is the same basic process as Method 2 for Product Explorer.
Add whatever assemblies or parts you want to package the PDFs, STEP, etc., from into a Bookmark.
Select all files (or the ones you want) and use the Export As command from the upper toolbar.
Using 3DEXPERIENCE Bookmark Editor
As before, the downside to this method is that you will have to delete the CAD files from the resulting .zip files to only have the Derived Outputs left.
However, the upside is that you can do many assemblies at the same time or even many unrelated files if needed.
Now you know how to get the data you need out of the 3DEXPERIENCE platform, packaged up, and ready to send off to anyone outside of the platform!
Want to learn more? Check out more tips and tutorials listed below or on our 3DEXPERIENCE YouTube Channel. Additionally, check out the GoEngineer Community, where you can create forum posts, join design contests, and answer questions from other 3DEXPERIENCE platform users.
3DEXPERIENCE - Release Assembly and All Related Files
Accessing the Cloud Using Design with SOLIDWORKS
Adding Columns to the 3DEXPERIENCE Bookmark Editor App After July 2025 Update
3DEXPERIENCE Engineering Release App to Add or Change Properties
Create Custom Attributes in the 3DEXPERIENCE Platform
Button
About Randy Simmons
Randy Simmons in a Sr. 3DEXPERIENCE Specialist at GoEngineer.
View all posts by Randy Simmons
