Antero 840CN03 is an engineered thermoplastic specifically designed for Stratasys F900 and Fortus 450mc FDM 3D printers. Antero 800NA is Stratasys' trade name for PEKK (of the same chemical family as PEEK), a robust thermoplastic known for its exceptional heat resistance, chemical resistance, and strength properties.
840CN03 is a variant enhanced with a unique additive: carbon nanotubes. This addition makes the plastic mildly conductive, allowing it to safely dissipate static and other electrical charges, rather than accumulating them for a potentially shocking discharge—much like a static shock you might feel after touching a doorknob while wearing thick socks in winter. This special feature is a key reason why Antero 840CN03 is popular in the aerospace and oil and gas industries.
This article discusses everything you should know about Antero 840CN03 to determine if it is suitable for your applications.
Antero 840CN03 shines for high-value, mission-critical parts that require ESD safety, high-temperature tolerance, chemical resistance, and low outgassing. Low-volume and high-complexity applications are best for FDM in general, but even more so for Antero 840CN03 (mainly due to cost). The aerospace industry tends to meet this criterion, with applications like interior components such as ducting, brackets, wire guides, or enclosures exposed to fuel or hydraulic fluids. Satellites and launch vehicles, as well as interior cabin parts, which often require low outgassing and electrostatic dissipativity, are also good aerospace applications.
The ESD properties of Antero 840CN03 are ideal for PCB and other static-sensitive part handling, such as the fixtures, jigs, tooling, robotic end-effectors, and dunnage found in automotive and electronics manufacturing. This electrostatic conductivity also has defense applications for shielded enclosures requiring EMI/RFI protection. These properties, combined with the heat and chemical resistance of PEKK, make this a suitable material for hazardous environments, especially those requiring frequent sterilization and/or proximity to sensitive electronic equipment.
Lockheed Martin Space has seven 3D printers in its Additive Manufacturing Lab, the latest of which is the Stratasys Fortus 900mc™, with its higher thermal capability and ability to print larger parts. With each capsule newly constructed for that flight, the importance of repeatability takes on a new significance.
Stratasys has performed a study on ULTEM™ 9085 resin, FDM® Nylon 12CF, and Antero™ 840CN03 to determine their fatigue properties. The samples for these tests were printed by Stratasys on an in-house F900® 3D printer and tested externally by a certified testing facility.
This study was conducted to characterize the chemical resistance properties of the Antero 840CN03 material formulation when exposed to representative chemicals commonly found in the aviation industry such as jet fuel, hydraulic fluid, and various acids, bases, and solvents.
Antero 840CN03 is an advanced thermoplastic for FDM 3D printing with applications far beyond the aerospace industry for which it was designed. If the parts you need require any combination of strength, chemical resistance, wear resistance, ESD-safety, heat resistance, and/or low outgassing, this is the material for you.
If you have questions or would like to learn more about Antero 840CN03 or any other Stratasys 3D printing material, please contact us.
GoEngineer offers comprehensive 3D printing services across multiple U.S. labs, equipped with cutting-edge Stratasys FDM, PolyJet, Stereolithography, P3, and SAF technologies for 3D printed prototypes or production parts. Request your quote online today!
FDM Post-Processing: Oryx sca1200ht for Soluble Support Removal
NASCAR Names Stratasys as Official 3D Printing Partner
GrabCAD Print Pro Thickness Analyzer for FDM Parts
Proven Performance: The Stratasys FDM Advantage
How 3D Printing is Helping Manufacturers Fight Back Against Tariffs
About Joseph Miller
Joseph Miller is a 3D Printer Technical Support Specialist based out of Atlanta, Georgia. He earned his Bachelor’s degree from Brigham Young University in 2008 and a Master’s degree from Capella University in 2013. Joseph has been working in the Additive Manufacturing industry for over 12 years and has been part of the GoEngineer family since 2019.
