How to Machine Large Hole Chamfers in CAMWorks
Article by Krystal Petersen on Nov 07, 2025
Cutting chamfers, where the size of the chamfer is much larger than the tool used, presents a unique set of problems. Once the hole becomes larger than the tool, the automatic chamfer abilities of the CAMWorks ContourMill operation cannot be used.
Under these circumstances, there are several ways of cutting the large chamfer, using a ContourMill or a Multiaxis (in 3-axis mode). This example uses the shape below to illustrate these methods.
This illustrates the use of a pocket (the use of a MultiStep hole is also possible).
Using a Taper Feature and a Countersink Tool
The countersink tool uses the bottom (or End) diameter (D3 below) to calculate the toolpath, so specific values have to be set to account for this when cutting a tapered feature.
  1. Create a circular pocket using the top of the chamfer. Make it a taper feature. In this example, the taper is 59deg.
  2. Generate a ContourMill and adjust its parameters. The most important parameters are the tool used, the depth of first cut, and the allowance.
  3. Define the tool as a countersink.
    Using a Taper Feature and a Countersink Tool in CAMWorks to Machine Large Hole Chamfers
  4. Side Allowance must be set to a negative value:
    Set this allowance to (D3÷2) - (D1÷2). This is (-.1375) for the tool shown above.
  5. The first cut must be set to ((D1÷2) - (D3÷2)) ÷ tan(angle A÷2).
For the tool shown above, this is
                              (D1÷2) – (D3÷2) = 0.1375
                              (0.1375) ÷ tan(59°) = 0.0826
The resulting cut, showing the tool at the edge of the pocket:
How to Machine Large Chamfers in CAMWorks
Note the position of the tool relative to the chamfer and the bore.
Using a Taper Feature and a Taper End Mill
The taper end mill uses the diameter of the body to calculate the toolpath. The specific values are different than when a countersink is used.
  1. Describe the same circular taper pocket as above. The feature has to have a depth larger than what will become the first cut.
  3. Describe the tool as a taper end mill. Note that the system calculates the maximum diameter based on the Taper angle (A), the End diameter (D1), and the Flute length (L2):
    Using a Taper Feature and a Taper End Mill to Machine Large Chamfers in CAMWorks
  4. Because the taper end mill calculates using the Max Diameter, the side allowance becomes 0, to place the edge of the tool at the edge of the circular opening.
  5. The first cut amount becomes
((MaxDiameter÷2) – (D1 ÷2)) ÷ tan(Angle A)
In the example above, this becomes
                  (1.6069÷2) – (0.625÷2) = 0.4909
                  0.4909÷tan(59°)=0.29499
Tool at End of Pocket in CAMWorks
Using a MultiAxis Operation
This involves using the same taper end mill as b. and setting the axis control to 3-axis.
Gouge protect should be used for the surfaces above the taper being cut, with the action taken to Move Tool Away, To Cut Center.
Remove Gouged Positions can also be used.
Depending on tolerance/finish requirements, the side allowance and first cut can be adjusted by a small amount to avoid the tool engaging the sides of the bore. Machine compensation is also available to properly size the cut.
Reassigning CAMWorks Licenses
What Is Feature-Based CAM and Why Is It Important?
7 CAMWorks Time-Saving Techniques
CAMWorks SOLIDWORKS OEM Installation
CAMWorks Network FNO License Activation/Renewal
VIEW ALL CAMWORKS ARTICLES
About Krystal Petersen
View all posts by Krystal Petersen
