CAMWorks Network licenses will sometimes forget what licenses to check out when you start the software. It knows it has a valid CAMWorks license, but the modules for the licenses don’t get pulled with the license. This can lead to greyed-out toolpaths or odd error prompts when clicking through the tabs. This can be easily fixed by reassigning the modules back to the software.
To fix this, go to the Help menu in the top right, then select CAMWorks > License Info.
From there, a new box will open displaying all the modules available with your CAMWorks licenses. To make those modules available on your machine again, scroll to the bottom and hit Select All.
Once all the options are selected, click Update Licenses. This will then pull the modules you’re entitled to back to that machine and allow you full use of the add-in.
What Is Feature-Based CAM and Why Is It Important?
7 CAMWorks Time-Saving Techniques
CAMWorks SOLIDWORKS OEM Installation
CAMWorks Network FNO License Activation/Renewal
About Krystal Petersen
