8 ALTAIR Inspire Cast Tips: Meshing Issues (Part 1)
Article by Drew Tucker on Apr 16, 2020
Tip #1: Common meshing issues – sleeves
Having trouble getting your high-pressure die casting simulation to mesh in  Altair Inspire Cast ? The problem may be in long, thin geometric features. Specifically the sleeve on a hot chamber shown in the example below.
Altair mesh issue sleeve
Typically, a die that has a hot chamber sprue will have a sleeve associated with it. In the real world, this sleeve covers the heating elements. In the simulation world, this modeled geometry adds unnecessary complexity by causing sections of the mesh to have zero thickness or force you to use a much denser mesh than necessary for the part. That being said, it has to be removed.
Altair Inspire Cast thickness
Altair Inspire Cast Mesh
Using the geometry tools in Altair Inspire Cast, we can easily remove this sleeve with a few cuts and modifications.
Altair Inspire cast geometry tools
The resulting part should have no problem meshing and not compromise the integrity of the overall simulation.
Altair Inspire cast Common Mesh issues sleeves
That wraps up the first quick tip in this series. Up next, we take a look at another common meshing issues: vents. Check it out here
If you have any questions or want to know more information about other Altair products like Inspire and HyperWorks please contact us .
About Drew Tucker
Drew Tucker is an Application Engineer for Manufacturing Solutions at Altair. He is the lead for Altair's explicit manufacturing simulation solutions in the Americas, and is heavily involved in metal casting & prototyping. Drew is a graduate from Western Michigan University's Engineering College and has over 10 years experience in manufacturing sector. Drew is focused on bridging the gap between additive and traditional manufacturing technologies specifically, through the use of simulation software.
View all posts by Drew Tucker
Subscribe
Get the latest articles delivered daily to your inbox, unsubscribe at any time.
