Welcome to part two of our blog series where we share eight quick tips for getting started in Altair Inspire Cast . In part one we addressed common meshing issues involving sleeves. In this blog, we’re taking a look at vents.
Having trouble getting your high pressure die casting simulation to mesh in Altair Inspire Cast ? The problem may be in long, thin geometric features. Specifically, vents.
These long, thin areas allow air to escape from the cavity, typically at the end of the fill. While they serve a great purpose in the real world, they can be problematic in the simulation world - specifically by creating odd meshed areas with no thickness. In addition, they won’t add to the overall quality of the simulation - so they’ve got to go!
You can either remove them in your CAD tool of choice or by using the geometry tools in Altair Inspire Cast. The Cut tool in the Geometry Toolbar should make quick work of these.
Select this tool, pick the bodies to partition, and cut them away.
Once cut, simply delete these separated vents. You’ll be left with a model that should run much easier and without compromising the quality of your simulation.
That wraps up our second quick tip in this series. In our next tip, we discuss another common meshing issue that occurs internally. Find out how to solve that problem here .
If you have any questions or want to know more information about other Altair products like Inspire and HyperWorks please contact us .
About Drew Tucker
Drew Tucker is an Application Engineer for Manufacturing Solutions at Altair. He is the lead for Altair's explicit manufacturing simulation solutions in the Americas, and is heavily involved in metal casting & prototyping. Drew is a graduate from Western Michigan University's Engineering College and has over 10 years experience in manufacturing sector. Drew is focused on bridging the gap between additive and traditional manufacturing technologies specifically, through the use of simulation software.
Subscribe
Get the latest articles delivered daily to your inbox, unsubscribe at any time.
