How to Add Gauge Table Templates in SOLIDWORKS
Article by Palmer Bubb on May 29, 2025
Sheet Metal is a feature in SOLIDWORKS that allows users to create bend and flat patterns simultaneously. When paired with the option to save files as .dxf for easy laser cutting, SOLIDWORKS becomes the preferred choice for industry leaders. SOLIDWORKS also allows users to create templates. These are starting points for your files, saving you even more time.
One of the advantages of using templates is that they allow you to preselect various settings, such as units and color selections, so you don't have to change them each time you start a new file. Sheet Metal has its own set of settings. One of which is the gauge table.
Whether you work with multiple gauge tables or just one, creating a template with the gauge table already selected can be very beneficial. However, a template that includes a gauge table can be a bit complicated, especially since sheet metal settings require a configured sheet metal feature. Let’s walk through the process of creating a template that incorporates a gauge table.
Adding a Gauge Table Template in SOLIDWORKS
  1. First, create a new file. Start your sheet metal part with just a line or a simple sketch. Check Use gauge table and select the table you want to use for this template.
  2. Delete the simple geometry you created. Notice how the sheet metal properties are still in the FeatureManger Design Tree.
    SOLIDWORKS Sheet Metal Properties in FeatureManager Design Tree
  3. Save the part as a Part Template.
    Save SOLIDWORKS Part Template
  4. Create a new file with the new template.
  5. How to Create a Template in SOLIDWORKS
  6. With the sheet metal properties in a simple template, if you have multiple frequently used gauges or materials, you can create as many templates as you need to cover those common options.
I hope you found this article explaining how to add gauge table templates in SOLIDWORKS helpful. Check out our tips and tricks below. Additionally, join the GoEngineer Community to participate in discussions, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
SOLIDWORKS Sheet Metal Training
Want to sharpen your skills? Learn to build stand-alone sheet metal parts and convert conventional parts in our Professional SOLIDWORKS Sheet Metal training course.
SOLIDWORKS Sheet Metal Lofted Bend Manufacturing Methods Bent & Formed
How to Create Sheet Metal Bend Notches in SOLIDWORKS
SOLIDWORKS Sheet Metal Sketched Bend Tutorial
SOLIDWORKS Convert to Sheet Metal Command Explained
SOLIDWORKS Drawings – Unable to Dimension Sheet Metal Bend Lines
VIEW ALL SOLIDWORKS TUTORIALS
About Palmer Bubb
Palmer Bubb is a Technical Support Engineer and Certified SOLIDWORKS Expert (CSWE). Prior to joining the technical support team in 2021, Palmer designed retail fixtures for major retailers such as Lowes, Publix, Meijer, and Harbor Freight. He graduated from Northern Illinois University with a degree in Mechanical Engineering. Palmer enjoys weightlifting, local coffee shops, book stores, and live music.
View all posts by Palmer Bubb
