If you’re having trouble installing a SOLIDWORKS PDM Standard client or server, there are a few common errors to check. These errors include firewall ports, a database that has already been created, and using “localhost” instead of the computer name. Learn more about these common installation errors in SOLIDWORKS PDM Standard here.
Firewall ports 1433 and 3030 must be open. To check if the ports are open, run a telnet test.
Telnet Test:
If the ports are still failing even after adding an exception to the firewall, Enable remote TCP/IP connections.
If installing a NEW SOLIDWORKS PDM Standard database, occasionally an instance is already installed, or if a previous installation fails, the default instance has already been created. There are two possible solutions.
When installing SOLIDWORKS PDM Standard, it is important to use your computer name instead of “localhost”. Change from “localhost”, to your server name on the SQL server name.
Update SOLIDWORKS PDM Dispatch Add-In & Backup Scripts
Setting Up Cold Storage in SOLIDWORKS PDM
PDM Check-In Dialog Box Columns...What Do They Mean?
GoEngineer delivers software, technology and expertise that enable companies to unlock design innovation and deliver better products faster. With more than 35 years' experience and tens of thousands of customers in high tech, medical, machine design, energy and other industries, GoEngineer provides best-in-class design solutions from SOLIDWORKS CAD, Stratasys 3D printing, Creaform & Artec 3D scanning, CAMWorks, PLM, Altair, and more
Subscribe
Get the latest articles delivered daily to your inbox, unsubscribe at any time.
