SOLIDWORKS PDM Mixed Authentication Logins
Article by Alex Hoang on Apr 07, 2026
SOLIDWORKS PDM 2019 and newer allows for mixed authentication of logins, meaning an administrator of a vault can set the option to allow users to log in as their Windows login from active directory and SOLIDWORKS PDM users. Previously, the administrator had to choose between setting up the vault logins with Windows users or SOLIDWORKS PDM users. The vault administrator can now have multiple users either with a PDM account and a Winodws login account access the vault at the same time.
How to set up Authentication Users with Mixed Logins
To authenticate users with mixed logins:
  1. Click Start > All Programs > SOLIDWORKS PDM > Archive Server Configuration.
  2. Select Tools > Default Settings.
  3. Select Windows login.
  4. Select Allow SOLIDWORKS PDM login.
  5. Click Apply and OK.
    How to Set Up Mixed Authentication Logins in SOLIDWORKS PDM
In the Administration tool, when adding a new user in the Add Users dialog box:
  • The renamed option, List Windows User, lists the Windows users defined in the archive server configuration tool available to add.
  • The renamed option, New Windows User, adds a Microsoft Windows user if you know the name of the user you'd like to add explicitly.
  • The new option, New SOLIDWORKS PDM User, adds a SOLIDWORKS PDM user.
    SOLIDWORKS PDM Authentication Users for Mixed Logins
Benefits of SOLIDWORKS PDM Mixed Logins
Mixed authentication in SOLIDWORKS PDM is beneficial because it provides the PDM Administrator with flexibility in determining how users access the vault, balancing security and accessibility. By supporting both Windows (Active Directory) and PDM logins, this allows users to log in seamlessly with their existing Windows login credentials while still allowing access for external users/contractors who might not be part of the company domain.
If there are any additional questions pertaining to the setup and configuration, we recommend consulting with your IT department and reaching out to our support team for any additional assistance.
Editor's Note: This article was originally published in March 2019 and has been updated for accuracy and comprehensiveness.
More SOLIDWORKS PDM Tutorials
How to Set Up Dynamically-controlled Card Lists in SOLIDWORKS PDM
SOLIDWORKS PDM and SQL Server Performance Considerations
New SOLIDWORKS PDM Column Configurations
SOLIDWORKS 2022 Data Management: PDM, Manage, & Admin
About Alex Hoang
Alex Hoang is a Sr. Technical Support Engineer based in Seattle, Washington. He holds Administrative PDM and Certified SOLIDWORKS Professional (CSWP) certifications. Alex graduated with a Bachelor's degree in Mechanical Engineering from Washington State University and has a strong foundation in using SOLIDWORKS and data management software, allowing him to better understand customer needs. In his spare time, he enjoys playing tennis, training for marathons, and spending time outdoors.
View all posts by Alex Hoang
