When working in CAD environments like SOLIDWORKS or 3DEXPERIENCE, you may see terms like CAD Families, Physical Products, and Representations. These concepts are connected, and understanding how they work together can help engineers, designers, and manufacturers manage their data more effectively.
According to a Dassault Systèmes Help File, “CAD Family is the main object in 3DEXPERIENCE that can assist you to create different SOLIDWORKS configurations from one CAD Family. When you create a part or an assembly, you create a configuration of that object. You can also create another configuration having some unique features of that same object. The 3DEXPERIENCE platform displays all these configurations as physical products. Hence, all the physical products are linked to a CAD Family object from which they are generated.”
In other words, a CAD Family is a group of related CAD models, which can be a Part or Assembly that shares a common design intent but may be different in configuration, size or options.
For example, consider a family of open-end wrenches: 1/4, 5/16, 3/8, etc. Each variation is part of the same family because they share the same overall purpose and general geometry.
In SOLIDWORKS terms, this would translate to configurations or design tables, where one “master” model controls multiple variations.
In 3DEXPERIENCE, CAD Families help organize these variations, so you do not treat each instance as a completely separate design file.
The key benefit of CAD Families is that it lets you manage design intent once, while supporting multiple product variations.
A Physical Product represents the real-world item you intend to manufacture, assemble, or sell.
For example, a specific open-end wrench from the wrench family would be “BigBrand” Combination Wrench: alloy steel, chrome, 1/2" head size, 7" overall Length, offset, rounded, part number CW-ASC127R. This is a physical product.
It is not just geometry; it also carries metadata, like part number, material, finish, and supplier information. In data management systems, the physical product links directly to manufacturing and the Bill of Materials.
The key benefit of a Physical Product is that it bridges the gap between CAD design and business processes.
According to this Dassault Systèmes Help File, “A representation is a child configuration of a physical product. A representation shares a part number with the parent physical product to represent a state of the physical product. For example, an exploded state. Representations are not saved to the 3DEXPERIENCE platform.”
These three concepts form a data management ecosystem:
Together, they ensure consistency, traceability, and efficiency across the Product Lifecycle Management (PLM).
The CAD Family tab in SOLIDWORKS is where you can view, create, and manage Physical Products (design variations/configurations) and Representations as part of a CAD Family. This feature is especially useful if you are working on the 3DEXPERIENCE platform or need to keep multiple part versions organized. The following steps explain how to activate the CAD Family tab and manage it.
Depending on the option you enable in System Options > 3DEXPERIENCE Integration, you will either, by default, have a single Physical Product without a CAD Family or, as in the image below, a CAD Family with a default Physical Product and the capability to add additional Physical Products. However, you can add and remove CAD Families.
Understanding how CAD Families, Physical Products, and Representations work together ensures that:
In a nutshell, CAD Families define the design space, Physical Products make it a reality, and Representations make it usable for everyone in the display necessary for their task. These tools get your designs to market faster by saving time, reducing errors, and helping your organization work efficiently.
Want to learn more? Check out more tutorials below. Additionally, check out the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
SOLIDWORKS Custom Property for Monitoring Surface Area
About Agustin Jimenez
Agustin Jimenez is an Application Engineer at GoEngineer based out of Fresno, California. He has a Bachelor’s degree in Electronics Engineering Technology from California State University, Long Beach and is a CSW-P certified in Weldments, Sheet Metal, and Mechanical Design.
