Table of Contents
In DriveWorks Pro, specifications are created either through DriveWorks Live or through the Specification Explorer in Administrator, User, or Autopilot. These specifications are variations on the original project CAD, along with other documents such as quotes and bills of materials.
When creating a new specification, the users are shown the form which had been created when setting up the project, and are now allowed to enter their specific desired parameters. Once completed, the models and documents are then customized according to the values filled out by the user and the model rules defined in the project. See an example form of a project for creating a simple block, driving the length, width, height, and color.
Once the values are set and the models and documents are released, DriveWorks saves out two files to the path defined in the Specification Settings, in a hidden folder named “DriveWorksFiles”.
This folder is hidden because it is not meant to be handled by the user. The files inside this folder contain all the model rules and variables defined when the specification was created.
Note: Since the model rules and variables are defined within this folder, if there are updates to the model rules in the project at a later time, regenerating the models for this specification will still use the model rules defined when the specification was created. In order to use the new model rules on an old specification, a new specification must be created with the same variables.
You can now see why it would be helpful to track the variables used for your specifications if you need to update your model rules and reflect those new rules on old specifications.
When it comes to exporting variables in a specification to a table, many will turn to group tables. If you plan on generating a large number of specifications, then the group table can get quite large. All group tables are loaded into RAM whenever a new specification is created for any project within your group, not just the one that updates the group tables. This can slow down your specification creation process.
Why not use a tool that was created for handling large amounts of data and allowing fast retrieval of that data? SQL Server tables can be used to store the specification variables, allowing for fast retrieval later on if necessary. You can use SQL Server Express to do this, so you do not need to go buy SQL Server Standard.
Note: The integration into SQL is only available for DriveWorks Pro. This functionality is not available in DriveWorks Solo or Xpress.
It is recommended to create a new database for this usage, to ensure it is isolated from other databases, such as a PDM vault or DriveWorks Shared Group database.
Now, when choosing Generate after filling out the form, the values from the specification are added to my Data table in SQL. I can use this table to re-run old specifications should I make changes to the model rules.
This is a fast and easy way to track all your specification variables, so that they can easily be recycled should old specifications need to be recycled with new model or document rules.
Working with Office Files in DriveWorks
DriveWorks Data Management: Back Up Your Data
Control DriveWorks Model Generation Order
Compare DriveWorks Packages: Features in DriveWorksXpress, Solo & Pro
DriveWorks Test Mode: Generate (On Demand) vs Generate (Queued Using Model Insight)
