Site Translation Underway
Contact Us
SOLIDWORKS PDM Vault Upgrade: Standard to Professional
As an organization grows, so does its vault. At a certain point, you just need to get a little more power thanSOLIDWORKS PDMStandard can provide. So now, you’re in this boat ready to upgrade to SOLIDWORKS PDM Professional, but you don’t know where to start. This guide will walk you through the process step by step to ensure you have the smoothest upgrade possible.
General Steps
Take backups of all the PDM components.
Install SQL Standard.
Upgrade PDM to Professional
This guide assumes that you are doing an in-place upgrade and not moving to another machine. If you need to move to a new server machine at the same time, refer to this guide first:Move Your PDM Server Components. You will need to plan for downtime to complete these activities, or you’ll want to perform the upgrade after hours. Users cannot be in the vault during any upgrade process. Please also note that this process is not reversible. A SOLIDWORKS PDM Professional vault can never be downgraded to a Standard vault.
On the Server
On the server, you will need to go through several steps. They must be done in this sequence to succeed.
Step 1: Take Full Backups of Your PDM System
You’ll need a backup of the following items. These backups are used to complete the upgrade and to recover all the PDM components in case something goes wrong:
Open the SolidNetwork License Manager Server on your License Server host machine.
On the Server Administration tab, click theModify button.
ChooseMove your product licenseorDeactivate, depending on your product version.
ClickNextuntil you reach the Activation page.
Ensure you select the PDM serial number(s) to deactivate, or clickSelect All.
ChooseAutomatically over the Internetand enter an email.
Finally, clickNext.
Add your new PDM Professional Serial Number to the SolidNetwork License Manager and remove the old one. Use this guide for that process:Add a Serial Number to the SNL.
Use the steps from Step 3, 1-2 to activate your new license. Simply chooseActivate/Reactivateinstead of Move or Deactivate.
Step 4: Upgrade Your Database to SOLIDWORKS PDM Professional in the PDM Administration Tool
Open theSOLIDWORKS PDM Administration toolby opening your Windows Start Search and typing Admin.
Log in to the Vault as Admin.
Right-click the vault name and chooseUpgrade to Professional Vault.
A Wizard will pop up.
ClickNexton theWelcomepage to begin.
On the next page, click the checkbox to agree and clickNext.
On theChoose Professional License Serverpage, ensure the License Server information in the window is correct and clickFinish.
Your vault will disappear from the tree in the Administration tool. This is because Standard installations cannot see Professional vaults. We’ll fix this in the next step.
Step 5: Modify Your PDM Standard Server Installation to PDM Professional
In your Windows Start Search, typeControland open theControl Panel.
ChooseProgramsorPrograms and Features.
Find your PDM Server installation from the list of products, right-click, and chooseChange.
The Server installation manager will pop up. ClickNexton the welcome page.
On theProgram Maintenancepage, selectModifyand clickNext.
On theSelect PDM Productpage, selectSOLIDWORKS PDM Professionaland clickNext.
On theServer Installationpage, make sure that the Archive Server, Database Server, and Client options are selected. You can also add Web features here, if you plan to use them. Then clickNext.
On theChoose Product Typepage, make no changes and clickNext.
On theSelect Add-Inspage, add any of the integration tools you may need. Then clickNext.
On theSOLIDWORKS PDM Database Server SQL Loginpage, enter your SQL Server name, as well as the login credentials for the SQL Server ‘sa’ user. Then clickNext.
Finally, clickInstallon theRead to Modify the Programpage.
When the wizard is finished, click theFinishbutton to close it.
Restart the machine.
Step 6: Transfer Your Database from SQL Express Edition to SQL Standard Edition
On the SQL Server, open the SQL Server Management Studio (SSMS). Then, log in to both the SQL Express and the SQL Standard instances.
Right-click Databases from the SQL Standard instance, and chooseRestore Database.
On theGeneralpage:
SelectDevice.
Click the…button and navigate to and choose your database backup.
Make sure theRestorecolumn check box is selected for the backup.
On theFilespage:
Click the check box forRelocate all files to folder.
The fields will automatically fill in with default locations.
ClickOK.
A success notification should appear.
Repeat this process for each database that is being moved to SQL Standard.
Now you’ll see the Databases appear in the Object Explorer under the SQL Standard instance.
Step 7: Update the Server Registry Keys
Open the Registry Editor.
Navigate to the key Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise\MailService.
Change theServervalue to match the new SQL Standard Database Server name. In this example, we just drop the \MSSQLSERVER at the end of the value.
Step 8: Test
Open the SOLIDWORKS PDM Administration tool.
If the upgrade was successful, your vault will appear in the tree again. Now, it will have a gold cylinder icon next to it, where before it had a silver icon.
Attempt to log into the vault as theadminuser.
On the Client/Workstation
On the client machines, you will need to go through a few more steps, and they must be done in this sequence to succeed.
Note: If you have installed SOLIDWORKS PDM using an Administrative Image, you will need to uninstall PDM Standard and install PDM Professional. Administrative Image installations cannot be altered. For a clean uninstall of the PDM Client, please read this guide:PDM Client Clean Uninstall.
Step 1: Modify the Client Installation from PDM Standard to Professional
In your Windows Start Search, typeControl, and then open theControl Panel.
Find your SOLIDWORKS or PDM Client installation in the list of programs. Then right-click and chooseChange.
On the Welcome page, chooseModify Your Installationand clickNext.
On the Serial Number page, make no changes. Just clickNext.
If the Product Selection page appears, clickNextwithout making changes.
On the Summary page, click the blue or purpleChangeto the right ofPDM Options. You may need to scroll down to see this.
On the PDM Options page:
Choose SOLIDWORKS Professional PDM.
Make sure the correct Client Type is selected for the user.
Select the integration options you would like to include.
ClickBack to Summary.
On the Summary page, selectModify Now.
Step 2: Update the Registry
Navigate to the key Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise\Databases\VaultName.
Change the DbServer value to match the new SQL Standard Server name.
Navigate to the key Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\SolidWorks\Applications\PDMWorks Enterprise\Databases\VaultName.
Test that the Client connects to the Vault.
Repeat these changes on each client machine.
Want to learn more aboutSOLIDWORKS PDM? Check out more tips and tricks below. Additionally, join the GoEngineer Community to participate in discussions, create forum posts, and answer questions from other SOLIDWORKS users.
Alert
We Value Your Privacy
