Cut Material Costs by 20% with SWOOD - Smarter Nesting for Cabinet Manufacturers
 Article by Mike Dady on Jun 08, 2026
Material costs remain one of the most volatile variables in cabinet manufacturing. While many shops focus on buying faster machines or adding labor to increase throughput, one of the most overlooked opportunities for savings sits earlier in the process: how parts are nested before they ever reach the CNC.
SWOOD Nesting is a robust and practical tool that helps cabinet manufacturers consistently reduce sheet usage, improve machine efficiency, and gain better control over production.
SWOOD Nesting for Cabinet Manufacturers
The Real Cost of Inefficient Nesting
In many cabinet shops, nesting is either handled by basic CAM software or done manually with limited automation. The result is often:
  • Excessive sheet waste
  • Inconsistent yields between jobs
  • Extra machine time due to poor toolpath strategies
  • Difficulty accounting for grain direction, part priority, or material constraints
Even small inefficiencies add up. Saving a few square feet per sheet doesn’t sound dramatic until it’s multiplied across hundreds or thousands of sheets per year.
How SWOOD Nesting Optimizes the Bottom Line
SWOOD Nesting is built specifically for woodworking and panel-based manufacturing. Rather than forcing cabinetmakers to adapt to generic nesting logic, it reflects how real shops work.
Intelligent Part-in-Part Nesting
SWOOD Nesting doesn’t just line up boxes. It automatically arranges parts to maximize sheet utilization while respecting critical constraints. It looks for opportunities to tuck smaller parts (like toe kicks or stretchers) inside the voids of larger ones (like sink cutouts). This part-in-part logic is often where that 20% savings begins.
Multi-Sheet and Batch Optimization
Instead of nesting one cabinet at a time, SWOOD Nesting can process entire batches. This allows the software to find efficiencies across multiple jobs, often where the biggest material savings are found.
SWOOD Nesting Multi-Sheet & Batch Optimization
Real-World CNC Awareness
Nesting strategies are tied directly to tool selection, cutting order, and machine behavior. That means fewer air moves, cleaner cut paths, and reduced cycle times, all while preserving sheet integrity.
Scrap and Remnant Management
Usable remnants are automatically tracked and reused. Over time, this alone can significantly reduce the number of new sheets pulled from inventory.
When implemented properly, many cabinet manufacturers see material savings approaching or exceeding 20%, especially when replacing manual or lightly automated nesting workflows.
SWOOD Nesting Scrap and Remnant Management
Beyond Nesting: A Broader Look at SWOOD
While nesting is a major driver of cost reduction, it’s only part of what SWOOD brings to the table.
SWOOD is a fully integrated design-to-manufacturing solution built on SOLIDWORKS, connecting:
  • Parametric cabinet design
  • Accurate BOM generation
  • Material-aware CAM programming
  • Consistent CNC output
Because design and manufacturing data live in the same environment, changes made during design automatically flow through nesting, toolpaths, and output files. This eliminates common disconnects that lead to scrap, rework, or shop-floor confusion.
For engineering-driven cabinet shops, this closed-loop workflow is often just as valuable as the material savings.
Why This Matters Now
Margins in cabinet manufacturing are tight, and material volatility isn’t going away. Shops that rely on outdated nesting methods are effectively leaving money on the table with every sheet they cut.
SWOOD Nesting doesn’t promise magic; it delivers measurable, repeatable improvements by applying smarter logic to a problem that impacts every job.
Reducing material costs doesn’t always require new machinery or radical process changes. In many cases, it starts with making better decisions before the first cut is made.
By combining intelligent nesting with an integrated design-to-manufacturing workflow, SWOOD helps cabinet manufacturers turn efficiency into a competitive advantage.
Ready to Get Started?
If you’re evaluating ways to lower material usage, improve CNC efficiency, and gain better visibility into your production data, SWOOD Nesting is worth a serious look — especially with the implementation and support expertise available through GoEngineer.
Ready to Get Started with SWOOD? Contact GoEngineer to to Learn More About SWOOD Nesting
Discover how SWOOD Nesting can help you optimize material usage and enhance your CNC efficiency.
What's New in CAM 2026: SOLIDWORKS, CAMWorks, & More
SOLIDWORKS at Home: DIY CAD Projects
SOLIDWORKS Backyard Design Project
View All
About Mike Dady
Mike Dady is a Senior Application Engineer at GoEngineer. Mike spends his days working with customers to resolve their manufacturing issues and helps them to improve on existing product designs. If he’s not solving customer challenges, he’s probably at home customizing his snowmobile or working on a home improvement project.
View all posts by Mike Dady
