The latest enhancements to Routing for SOLIDWORKS 2026 are here! See what's new, including improved coverings for pipes and tubes, sketch-guided auto route, and the flexibility to automatically rescale drawing views for electrical routes.
Prior to SOLIDWORKS 2026, modeling custom coverings for pipes and tubes didn’t calculate the overall diameter or show the appearances accurately.
To add a covering to the route segment:
To use the applied layers to create a Favorite to be used again:
Once the Electrical route has been created, all the components have been added, and a From-To list has been added. A 3D sketch can be created at the top assembly level.
When creating flattened drawings of electrical routes, sometimes the default sheet size becomes too crowded with the views, tables, and annotations, and it become necessary to change the sheet format to a larger paper size. In previous versions of SOLIDWORKS, this has been tedious and time-consuming because of the requirement to scale the views, tables, and annotations separately.
In SOLIDWORKS 2026, moving to a larger sheet size is much simpler.
This is currently a D-size sheet, and I would like a bit more room to add additional annotations and give more room for the table, so I will make it into an E-size sheet.
That's a wrap for what's new in SOLIDWORKS Routing 2026. Check out the rest of our SOLIDWORKS 2026 What’s New series for more updates across the SOLIDWORKS platform.
SOLIDWORKS Simulation 2026 - What's New
SOLIDWORKS 2026 UI/UX, Performance & Imports - What's New
About Dennis Barnes
