Table of Contents
Early in my additive career, I met with many customers who wanted everything from a 3D printer: production quantity, properties, look, and feel. Unfortunately, the printers of that era just couldn’t deliver all of it. Fast forward to the 2020s, and those same customers are still asking for the same things, but we are now very close to answering the call.
Fast powder-based machines such as the Stratasys H350, which uses Selective Absorption Fusion (SAF) technology, have significantly improved the quantity, properties, and feel of printed parts. The final aspect we need to address is the look. Specifically, I want to focus on the final color of SAF-printed parts and the potential addition of a DyeMansion DM60 for color finishing.
The SAF process rolls out a layer of nylon powder, jets a black High Absorbing Fluid (HAF) onto the areas to be fused, and then hits the bed with a very high-intensity light. The black fluid absorbs the light, so those areas melt and fuse, layer by layer.
Parts come out of the machine a light gray color. They are functionally fine as printed, but if your application needs a specific color, the DM60 is the answer.
At its heart, the DM60 is a system for dyeing your parts easily and repeatably to get the look you need. It was designed and built to keep up with busy production floors.
With an 80-liter process chamber, a single 150-minute cycle can handle a large batch of parts. To give you an idea of its capacity, one run can color about 1.5 full Stratasys H350 builds.
The system works so well because of DyeMansion’s process control and chemistry. Each color cartridge carries an RFID chip that loads its recipe and process parameters into the DM60 automatically, so every run follows the same recipe.
If you run multiple printers and dye mostly black, the DM60 Reservoir add-on reuses the dye bath across runs, which shortens cycle times and cuts both water use and wastewater.
Today, you can choose from more than 170 RAL and standard colors, depending on the material. The dye penetrates the surface of the part instead of sitting on top as a coating, so no material layer is added and the color won’t chip or peel. DyeMansion also holds ISO-based certifications for biocompatibility (cytotoxicity and skin irritation) and color fastness on validated material, color, and finish combinations.
I’ve been asked a few times, “Couldn’t I just throw my parts in a hot water bath with some Rit dye?”
Technically, yes, you could, but should you? I put this to the test. I mixed a double-strength batch of black Rit dye in very hot water, soaked a set of SAF parts in it for several days, and checked on them occasionally.
After drying, the parts were a little darker, but not black. They were also inconsistent from one part to the next and a little streaky. That is hard to see in the photo below, but very noticeable in person.
Even color also depends on what happens before dyeing. DyeMansion recommends cleaning parts and, in most cases, surfacing them before they go into the DM60, because a uniform surface takes the dye more evenly. GoEngineer offers DyeMansion’s Powershot systems for both steps, so cleaning, surfacing, and coloring can run as one consistent workflow.
Reach out to us at GoEngineer to start the conversation. We can talk through your parts, colors, and volumes, and how the DM60 fits alongside your H350. You can also explore the full lineup of DyeMansion finishing systems.
About Jeremy Marvin
Jeremy Marvin is a Senior Digital Manufacturing Application Engineer at GoEngineer.
