Adding User Defined Turning Tools to CAMWorks
 Article by Justin Mathis on Apr 07, 2026
In SOLIDWORKS CAM and CAMWorks, the Technology Database (TechDB) allows for adding user defined tools. The process for adding Turning tools is a little different than that of adding Mill tools.
Turning tools can be imported as an assembly, the Turning Insert, and the Turning Tool Holder. You can add just the Turning Insert to your library, but since many manufacturers can provide a 3D model of the tool and insert, we’ll focus on adding a user defined Turning tool from a model of the new tool and insert.
The process involves 3 steps:
  • Create a Coordinate System for the insert and holder in the assembly
  • Add the User Defined Tool to the TechDB
  • Select the User Defined Tool for the Operation
Create the Coordinate System for the User Defined Tool
We’ll start by opening the 3D model of the tool we want to add to the TechDB. In this case, the tool came from the tool manufacturer as a .STP file, so it will need to be imported.
Add .STP File into CAMWorks Tech DB
Once the .STP is imported, there should be two parts in the assembly CUT (insert) and NOCUT (holder).
Create a Coordinate System for a CAMWorks User Defined Tool
We now need to create a coordinate system that will allow the tool to be properly oriented for our machine. To do so, start by creating a sketch on the face of the insert and draw lines colinear to the edges of the insert and extended to where they would intersect. Add a vertical construction line from that point across the face of the insert. Where the line ends is not important (shown below). Close the sketch.
CAMWorks Coordinate System User Defined Tools
Now, create a Coordinate System by selecting the Assembly tab in the Control Manager, Reference Geometry > Coordinate System.
How to Access the Coordinate System Option in CAMWorks
We need to create a Coordinate System that will correctly orient the tool for our machine. In this case, we want the tool orientation to be down left.
Down Left Orientation Option in CAMWorks
To accomplish this, we’ll create the Coordinate System at the virtual sharp of the insert we created in our sketch, with the X-axis along the construction line of our sketch, and the Y-axis normal to the body of the tool holder.
CAMWorks Assembly Coordinate System Axis
Hit the green check to save the assembly to the desired location.
Add a User Defined Tool to the TechDB
Now, we’ll need to add this tool to the TechDB. Open the TechDB and select the Turn Tooling tab from the left panel, then Inserts > User Defined.
Add a User Defined Tool to the CAMWorks TechDB
There is no “Add” option, so we’ll need to copy an existing insert, enter the appropriate insert thickness (.1875 in this case), and a description. Since we have the full assembly of the insert and tool, we do not need to link the insert part file here. Click save and return to the Turn Tooling tab, then select Holder > Assembly Tools.
CAMWorks Assembly Tools
As with the insert, we’ll need to copy an existing tool. Change the Insert Type to User Defined, and select the insert just created.
Change the Insert Type to User Defined in CAMWorks
Add a Comment and Description for your tool, click Save, and close the TechDB.
Add Comment and Description to a User Defined Tool in CAMWorks
In SOLIDWORKS, select the toolpath that will use your user defined tool. Right-click on it and select Edit Definition.
Select the User Defined Tool for the CAMWorks Operation in SOLIDWORKS
In the Operation Parameters, select the Tool > Tool Crib.
CAMWorks Open Parameters Tool Crib
Click From Library > Add.
Change the Tool Type to Turn Tool.
CAMWorks Tool Select Filter Tool Type Options
Then change the Turn Insert Type to User Defined.
Change Insert Type to User Defined in the CAMWorks Tool Select Filter
The user defined tool should be available. Select it and click OK.
CAMWorks Tool Select Filter Turn Insert Type
In the Tool Crib tab, select the new tool.
Select a User Defined Tool in CAMWorks Tool Crib
Now we’ll link the tool with the assembly we created earlier. Navigate to the User Defined Insert sub-tab of the Tool tab and click on the ellipsis.
User Defined Insert Sub Tab of the CAMWorks Tool Tab
Navigate to the folder your tool assembly is saved in, change the file type to view SOLIDWORKS files, and select the tool assembly.
Open CAMWorks Tool Assembly
Since we are setting up the insert, select the CUT component and ensure that the coordinate system that was created is selected.
CAMworks Select Part as Turn Insert
Next, click on the Holder sub-tab of the Tool tab. Change the Shape to User Defined.
Select a User Defined Shape in CAMWorks Operation Parameters
Click on the ellipsis to add the file path for the tool holder. Navigate to the same location as the insert and change the File Type to see the SOLIDWORKS assembly. Ensure that the correct Coordinate System is selected, and this time, we’ll choose the NOCUT, since it's just the holder we want.
Select the Components of an Assembly as Holder in CAMWorks
The insert and holder should now display correctly in the preview and the model.
Insert and Holder Displaying Correctly in the Preview and the Model in CAMWorks
Finally, you can step through the simulation to verify that the tool is oriented properly.
Step Through Tool Path Simulation in CAMWorks
Successfully adding user defined Turning tools to the Tech DB in SOLIDWORKS CAM and CAMWorks enhances machining capabilities by allowing for precise customization. By following the outlined steps, users can ensure optimal tool orientation and functionality for their specific machining operations.
Want to learn more? Check out more tips and tricks listed below. Additionally, check out the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS and CAMWorks users.
CAMWorks Broaching - Turn Setup & Mill Setup
Clearing CAMWorks Temp Files
When to Use an Open Pocket Without Sketches in CAMWorks
What's New in CAM 2026: SOLIDWORKS, CAMWorks, & More
How to Machine Large Hole Chamfers in CAMWorks
VIEW ALL CAM ARTICLES
About Justin Mathis
Justin Mathis is a Mechanical Engineer based out of Columbus, Ohio. He holds a CSWE certification and has 15+ years experience in machining and manufacturing. Justin has been part of the GoEngineer family since August 2024 as a Support Engineer. He likes to spend his off time volunteering in his community, homebrewing, and traveling.
View all posts by Justin Mathis
