Often a SOLIDWORKS user will have the wrong file location paths for an installation of SOLIDWORKS, which can cause the program to either fail or produce ineffective behavior. This article provides a clearly defined outline of the referenced paths that SOLIDWORKS requires to perform correctly.
Note: You may have to close SOLIDWORKS to save the options and file location(s)
| Document Templates | C:\ProgramData\SOLIDWORKS \SOLIDWORKS version\templates |
| C:\Program Files\SOLIDWORKS | |
| Corp\SOLIDWORKS\lang\english\Tutorial | |
| Bend Table Template | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| BOM Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Color Swatches | C:\Program Files\SOLIDWORKS |
| Corp\SOLIDWORKS\lang\english\colorswatches | |
| Costing Report Template Folder | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Costing templates | C:\Program Files\SOLIDWORKS |
| Corp\SOLIDWORKS\lang\english\Costing templates |
| Custom Property Files | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\lang\english |
| Design Library | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\Design Library |
| Dimension/Annotation Favorites | C:\Users\user\Documents |
| DimXpert Callout Format File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Hole Callout Format File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Hole Table Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Punch Table Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Revision Table Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Search Paths | C:\SOLIDWORKS Data\ |
| Sheet Formats | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\lang\english\s heetformat |
| Sheet Metal Bend Line Note File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Sheet Metal Bend Tables | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\Sheetmetal Bend Tables |
| Sheet Metal Gauge Table | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\sheet metal gauge tables |
| Sustainability Report Template Folder | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Symbol Library Folder | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\lang\english |
| Title Block Table Template | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Weld Table Template | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Weldment Cut List Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
| Weldment Profiles | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\weldment profiles |
| Weldment Property File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\Weldments |
