SOLIDWORKS AI Blue Tokens - FAQ
 Article by Baily Nemerofsky on Oct 15, 2026
SOLIDWORKS AI Virtual Companions, AURA and LEO, bring conversational AI into the design workflow. Blue Tokens provide a shared, usage-based way to access their metered AI skills.
Information current as of September 4, 2026
2,100
One-time introductory Blue Tokens per eligible commercial user
25,000
Blue Tokens per additional pack, expiring and auto-renewing every 12 months
1 shared pool
Held at the organization’s 3DEXPERIENCE platform tenant level
What are SOLIDWORKS AI Blue Tokens?
Blue Tokens measure usage of metered AI skills performed by SOLIDWORKS Virtual Companions. Tokens are consumed when a companion completes a metered task and returns a result. Simply opening a companion or using its interface does not, by itself, consume tokens.
Do I need Blue Tokens for every AI feature?
No. AI-assisted and intelligent capabilities that run within traditional SOLIDWORKS workflows do not consume Blue Tokens. Tokens apply to metered, cloud-connected skills delivered through AURA and LEO.
Who are AURA and LEO?
AURA and LEO are the SOLIDWORKS Virtual Companions (AI assistants).
AURA
Focuses on knowledge, guidance, and finding relevant information.
LEO
Focuses on mechanical design and engineering workflows in SOLIDWORKS Design, with skills that can support analysis, automation, drawings, assemblies, and other engineering tasks.
Do I need a separate SOLIDWORKS AI license?
For eligible commercial SOLIDWORKS offerings with Cloud Services, AURA and LEO do not require a separate Virtual Companion license. Their metered AI skills do consume Blue Tokens. GoEngineer can help confirm your licensing and Cloud Services configuration.
Are SOLIDWORKS AI capabilities finished products?
SOLIDWORKS AI is evolving rapidly. As of September 4, 2026, Virtual Companion skills are Early Access capabilities intended for evaluation, testing, and feedback. Skills, workflows, performance, and token consumption may change.
Note: AI-generated results should always be reviewed using normal engineering practices.
How many Blue Tokens are included to get started?
Each eligible commercial user receives a one-time introductory allocation of 2,100 Blue Tokens:
Source Blue Tokens
Qualifying SOLIDWORKS Design entitlement 2,000
3DSwymer 100
Total per eligible user 2,100
These allocations are combined into the organization’s shared token pool. The introductory allocation is provided once per eligible user and does not renew annually or monthly.
Are Blue Tokens assigned to individual users?
No. Although the introductory allocation is calculated based on the number of eligible users, the tokens themselves are placed in a shared pool at the organization’s 3DEXPERIENCE platform tenant level. Eligible users draw from the same available balance. Platform administrators can view the remaining balance in the Members Control Center.
How many tokens does an AI request use?
It depends on the work performed. SOLIDWORKS uses a value-based model: simple questions and insights generally use fewer tokens, while more involved analysis, design operations, or generative tasks use more. Consumption for individual skills may change as the technology evolves.
What happens when our Blue Tokens run out?
Additional tokens are required to continue running metered Virtual Companion skills. GoEngineer can help review expected usage and assist with purchasing more. Additional Blue Tokens are currently offered in packs of 25,000 that expire and auto-renew every 12 months.
Need more Blue Tokens or have questions about your setup?
GoEngineer can help review your environment, usage needs, and options for purchasing additional Blue Tokens.
Information reflects SOLIDWORKS AI availability and token guidance as of September 4, 2026. Capabilities and commercial terms may change.
About Baily Nemerofsky
Baily Nemerofsky is GoEngineer’s AI Solutions and Adoption Manager, a Certified SOLIDWORKS Professional, and a mechanical engineering graduate of Queen’s University. He is based in Toronto, Canada.
View all posts by Baily Nemerofsky
