WAZER Waterjet Systems Now Available in the U.S.
 Article by GoEngineer on May 20, 2026
At GoEngineer, our mission is to provide the tools that bridge the gap between digital design and physical product. Whether it’s through SOLIDWORKS Simulation or industrial 3D printing, we strive to give our customers a competitive advantage in achieving first-time-right manufacturing. We are excited to announce an expansion of that toolkit.
GoEngineer is now an authorized reseller of WAZER waterjet systems across the United States and Canada. While our Canadian customers have already been utilizing WAZER to bring industrial-grade cutting to their workbenches, we are thrilled to bring this capability to our partners in the U.S. market.
Wazer Waterjet Systems Now Available in the U.S.
The Missing Link
Why WAZER?
Most professional shops already have a mix of additive and subtractive tools. You might use a Stratasys system for complex polymer prototypes or a CNC mill for high-tolerance metal parts. However, there is often a missing link when it comes to cutting sheet goods or flat stock in diverse materials, like carbon fiber, glass, or hardened steel.
Traditional hot cutting methods, like laser or plasma, rely on intense heat that creates a heat-affected zone (HAZ). This can warp thin parts or alter the material properties at the edge, often requiring secondary machining to fix.
WAZER waterjet technology uses a high-pressure stream of water mixed with garnet abrasive to erode material away.
Because it’s a purely mechanical process, it offers several distinct advantages:
  • No Heat Distortion: Parts stay at room temperature, preserving the integrity of the material.
  • Material Agnostic: One machine can cut aluminum, stainless steel, glass, stone, rubber, and composites without changing specialized tooling.
  • Clean Edges: In many applications, the finish is smooth enough to go straight from the machine to the final assembly.
WAZER Desktop vs. WAZER Pro
Introducing WAZER to the U.S. provides our customers with two distinct options for in-house cutting, tailored to their production needs. Both machines offer a cutting area of 12” x 18” and 0.003” positional accuracy, but they are designed for different levels of intensity.
The Prototyping Essential
WAZER Desktop
WAZER Desktop was designed to fit into R&D labs and university workshops where space is at a premium.
WAZER Desktop CNC System
It runs on a standard 110V/60Hz circuit and uses a standard tap water hookup, making it a plug-and-play solution for on-demand parts. It’s perfect for cutting shims, custom brackets, or delicate glass components without the lead times of an external service bureau.
The Industrial Workhorse
WAZER Pro
For shops that demand higher throughput, the WAZER Pro is a game-changer.
WAZER Pro Waterjet Cutter
It features an integrated high-pressure pump that allows for 2x to 4x faster cutting speeds than the desktop model.
  • Thicker Materials: The Pro handles up to 1” aluminum and 3/8” steel with ease.
  • Heavy-Duty Cycle: Built for more frequent use, WAZER Pro includes a robust abrasive handling system and an integrated design that minimizes the shop footprint while maximizing output.
Streamline Your Workflow with WAM Software
A tool is only as good as the software that drives it. WAZER’s WAM software is a web-based CAM tool that allows you to import DXF or SVG files, select your material from a pre-loaded library, and automatically generate toolpaths.
WAZER WAM Software Interface for Waterjet Cutting
For SOLIDWORKS users, this means moving from a 2D sketch to a finished metal part in just a few minutes. Being able to iterate in end-use materials tightens the design loop and ensures that fit checks are accurate from the very first prototype.
Local Support for Your Industrial Future
Our commitment goes beyond just selling the hardware; we offer comprehensive technical support to assist you in integrating WAZER into your specific industry, whether it’s aerospace, medical device manufacturing, or industrial equipment design.
 Ready to Get Started?
Our team is ready to help you evaluate which WAZER system fits your needs and assist with the setup and maintenance that ensures your machine stays productive for years to come.
AI in SOLIDWORKS: What It Is (and What It Isn't)
The Hidden Cost of Late Engineering Changes: $5 M for 15 mm
Syncron Joins the GoEngineer Portfolio to Help Manufacturers Strengthen Aftermarket Performance
