3D Printed Dual Monitor Riser Designed in SOLIDWORKS
 Article by Brandon Lenoir on Jun 12, 2026
I recently designed this Han's Halo Dual Monitor Riser to complement my home workstation setup. But the problem is...how am I ever going to print this on my small 3D printer? In this blog, I'll detail the process I used to split a large model into 8 smaller pieces.
Dual Monitor Riser CAD Design
This design is over 30 in in length, which certainly can't be printed inside my printer's usable volume of ~ 10" x 10" x 10". But with a little bit of planning, I'm sure I can get there.
I started by creating a sketch in SOLIDWORKS on the top plane. I added rectangular sketch shapes corresponding to the size of my printer's build plate.
SOLIDWORKS Design with Sketch Shapes Corresponding to 3D Printer Build Plates
In this case, I'm using dimensions no larger than 9.8" to allow for any connector features I'll need to add later.
3D Printer Build Volume in SOLIDWORKS
This layout sketch is meant to plan the splits and is intentionally left under-defined, so that I can easily move things around.
Under Defined SOLIDWORKS Sketch
Once everything is positioned, it's time to split the model into 8 pieces. I've used the Split feature to do this. Split is found in Insert > Features > Split, but you can always locate hard-to-find commands by using the Command Search (press the 'S' key and start typing).
Ways to Access the Split Feature in SOLIDWORKS
Split is a powerful tool, but I'm going to use its most basic function to turn this model into a multi-body part file. I've selected the layout sketch as the Trim Tool and clicked the Cut Part button. Notice the 8 Resulting Bodies listed in the screenshot below.
SOLIDWORKS Spit Feature Trim Tool
This resulted in 8 bodies in the Solid Bodies folder, each of which can be modified independently.
SOLIDWORKS Solid Bodies Folders
In order to assemble these printed parts, they'll need something to hold them together. I'm going to use simple 0.5" long by 0.375" round prongs. For a snug fit, the acceptance holes are .005" oversized.
Han's Halo Dual Monitor Riser SOIDWORKS Model
The printed parts went together nicely, and I added some acrylic discs to fill the holes.
8 Separate 3D Printed Parts for a Dual Monitor Riser
If you like the look of this, feel free to download it and print one of your own.
More DIY Projects
Creating HAL 9000 Model Parts in SOLIDWORKS
SOLIDWORKS at Home: DIY CAD Projects
SOLIDWORKS Backyard Design Project
Full Iron Man Helmet Project
Wonder Woman Costume Comes to Life with 3D Printing, 3D Scanning, and 3D Design
View All Articles
About Brandon Lenoir
Brandon is a SOLIDWORKS Technical Support Engineer at GoEngineer.
View all posts by Brandon Lenoir
