There are two ways to save a SOLIDWORKS file to be used in Adobe Illustrator. The easiest way is to orient the part or assembly how you want to view it, and under the File tab, select Save As… and change the file type to Adobe Illustrator Files (*.ai). This method will work but can often result in a file that is difficult to work with because the file carries over the color gradient into Adobe Illustrator.
A better method is to save the view you want as a .dxf file that can then be opened into Adobe Illustrator without any color or gradient information. There are two ways to do this.
The first is to orient the part or assembly how you want to view it and, under the File tab, select Save As… and change the file type to Dxf (*.dxf).
The alternative and preferred way is to create a SOLIDWORKS drawing from the model with multiple views that you will want in Adobe Illustrator and save the views as .dxf files individually. The reason for this method is to have a master drawing file that contains all the views that you use that will be automatically updated if the model is updated. You can then quickly and easily re-export the updated views as .dxf files.
You can now bring all your .dxf files into Adobe Illustrator and if your model changes in the future you can quickly and easily create updated .dxf files for future use.
Saving a SOLIDWORKS File as a PDF vs Print to PDF
SOLIDWORKS Check Sketch for Feature Tool Explained
How to Install and Troubleshoot Fonts in SOLIDWORKS
About Brian Childree
Originally from Montana, Brian served in the US Air Force where he did machining and welding on A-10s and F-16s while stationed in Alaska and Afghanistan. He’s worked as a Design Engineer in multiple industries from medical, oil and gas, aerospace, consumer products and even interior lighting design. He graduated from the University of Utah’s Mechanical Engineering program and now works at GoEngineer as an Applications Engineer specializing in Simulation analysis.
