Optimizing Your Workstation Budget for Design & Engineering Applications: Rendering and Visualization
Article by GoEngineer on Sep 14, 2022
This article is part two of a 5-part series that provides guidance on how to optimize your workstation purchase for different CAD workflows. Introductory materials and the first article covering basic and advanced CAD can be found here.
This blog covers rendering and visualization. In all, this series covers the following workflows:
In each of these articles, we’ll discuss which components of the workstation are important to that workflow and provide some sample configurations to help optimize your spending budget.
Workflow: Rendering and Visualization
SOLIDWORKS Visualize leverages 3D CAD data to create content that is print and web-ready in minutes. It helps users select, validate, and improve robust design concepts before committing expensive engineering, prototyping, and marketing resources to a project. An important feature of SOLIDWORKS Visualize is its design, which highly leverages one or many GPUs (especially NVIDIA RTX GPUs), dramatically increasing rendering performance above and beyond “normal” CPU hardware.
Car Interior Rendered in SOLIDWORKS Visualize
Because of its design, SOLIDWORKS Visualize is all about GPU performance — which means extra attention should be paid to the quantity and quality of the GPUs in your workstation. Ray-tracing rendering times can be significantly reduced through the selection of a higher-powered GPU or the addition of multiple GPUs (since GPU rendering can be scaled across more than one GPU). The NVIDIA RTX series offers a wide range of high-performing solutions, from the accessible (and recommended minimum) NVIDIA RTX A2000 GPU up to the NVIDIA RTX A6000 GPU.
When selecting CPU specifications, keep in mind that performance and efficiency increase with each generation of CPU, so it’s important to note the generation of the processor. Even though CPU specs play a somewhat less important role for SOLIDWORKS Visualize, 4-8 core Intel 11th or 12th Gen i5, i7, or i9 processors are recommended.
For system memory, look for a minimum of 32 GB of RAM. Also, if the workstation architecture supports multiple memory channels, it’s a performance plus, but that feature needs to be weighed against its increased cost.
Finally, it’s important to select a workstation configuration that the hardware vendor tests and validates for your specific application. For example, Dell and GoEngineer have worked with SOLIDWORKS to create prepackaged configurations specific to a workflow; these configurations are a thoroughly tested combination of hardware components that eliminate incompatibility or performance issues.
To summarize, component suggestions for basic through advanced visualization workflows:
Component Suggestions
CPU Intel 11th or 12th Gen Intel Core i5, i7, or i9
GPU NVIDIA RTX A2000 and above
RAM Minimum 32 GB
Storage SSD with NVMe interface
Packaging  Desktop
Application Testing & Validation Select specific rendering and SOLIDWORKS Visualize workflows at the GoEngineer Dell Expert Network Portal.
Hardware Recommendations for SOLIDWORKS Visualize
For intermediate to advanced rendering and SOLIDWORKS Visualize work, the Dell Precision 7760 mobile workstation is a perfect platform for mobile applications. For deskside applications, the Dell Precision 3660 is an excellent entry point visualization workstation that supports a single double-wide GPU.
DELL Precision 7760 and Dell Precision 3660 Workstations Suitable for Immediate to Advanced Rendering and SOLIDWORKS Visualize
Left: Dell Precision 7760, Right: Dell Precision 3660
The Precision 5820 and the Precision 7920 tower workstations are excellent choices for high-powered visualization workstations—supporting up to 18 and 56 Xeon processor cores respectively. The Precision 5820 support two double-wide GPUs, such as the RTX A6000. The Precision 7920 supports three double-wide GPUs to further accelerate complicated SOLIDWORKS Visualize designs.
DELL Precision 5820 and Dell Precision 7920  Workstations Suitable for Complicated SOLIDWORKS Visualize Designs
Left: Dell Precision 5820, Right: Dell Precision 7920
Conclusion
Dell and NVIDIA offer a curated lineup of Precision workstations with NVIDIA RTX GPUs that provide a full range of options for rendering and visualization workflows. Along with flexibility for scaling memory, storage, and graphics to support higher complexity designs, these workstations are tested and validated with SOLIDWORKS applications.
These workflow-based configurations, along with additional learning resources (and an additional discount!), can be viewed at the dell.com/goengineer portal. The portal simplifies the selection of an optimized, tested, and validated solution that maximizes every budget dollar.
Optimizing Your Workstation Budget for Design and Engineering Applications
Best Docking Stations for SOLIDWORKS
Best Monitors for SOLIDWORKS
SOLIDWORKS Visualize Appearances and Hardware Utilization
SOLIDWORKS Visualize 2022: New Shadow Catcher, Camera Views, Animations, & More
VIEW ALL ARTICLES
