SOLIDWORKS 2026 Routing - What's New
 Article by Dennis Barnes on Nov 11, 2025
The latest enhancements to Routing for SOLIDWORKS 2026 are here! See what's new, including improved coverings for pipes and tubes, sketch-guided auto route, and the flexibility to automatically rescale drawing views for electrical routes.
Create Custom Coverings
Prior to SOLIDWORKS 2026, modeling custom coverings for pipes and tubes didn’t calculate the overall diameter or show the appearances accurately.
To add a covering to the route segment:
  1. Turn on the Routing add-in.
  2. Right-click on the route and select Edit Route.
  3. Then, right-click on the sketch segment and select Add/Edit Covering > Covering.
    SOLIDWORKS Routing 2026 Use Covering Library
  4. Add any additional route segments requiring coverings.
    SOLIDWORKS 2026 Routing Custom Coverings
  5. Select from the dropdown list of coverings from the library, or select Create custom covering.
    Select Material SOLIDWORKS 2026 Routing
    • For a custom covering, click Select Material.
  6. This will open the SOLIDWORKS Materials Library.
    SOLIDWORKS 2026 Materials Library
  7. Select the material required, then click Apply, then Close in the Material dialog, and click on the Apply button in the Covering PropertyManager.
  8. Set the covering thickness and add any additional route segments. Click OK.
  9. To add another custom material, repeat steps 6 and 7.
  10. If you want to change the order of the layers or to delete any, use the up or down arrows in the Covering Layers area.
    SOLIDWORKS 2026 Routing Covering Layers
  11. Click on the green check mark to complete the covering, then exit the sketch and the subassembly to see the results.
    SOLIDWORKS 2026 Routing What's New
Save Covering Favorites
To use the applied layers to create a Favorite to be used again:
  1. Repeat steps 2 & 3 above.
  2. Select the Add to Favorite icon in the Covering PropertyManager.
    SOLIDWORKS Routing 2026 Add Favorite Icon
  3. Then give the Favorite a name (like "Vermeer”) and click OK.
    Add a Favorite Covering SOLIDWORKS Routing 2026
  4. Exit the Covering PropertyManager.
  5. Repeat Step 1 above, but select a different Route.
  6. Select the sketch segments, then select “Vermeer” from the Favorites dropdown and click the Apply button. (This will apply the previously used layer’s material order and thickness to the current route.)
    SOLIDWORKS 2026 Covering PropertyManager
  7. Click OK and observe the results.
    SOLIDWORKS Routing 2026 What's New Save Covering Favorites
Use Guidelines in the Auto Route Function to follow 3D Sketches and Drive the Route
Once the Electrical route has been created, all the components have been added, and a From-To list has been added. A 3D sketch can be created at the top assembly level.
SOLIDWORKS 2026 Routing 3D Sketch Assembly Level
  1. Edit the route and select Auto Route. Turn off the orthogonal route in the first option.
    SOLIDWORKS 2026 Auto Route
  2. Select Guidelines, Follow Routing Path, click on the 3D sketch, and select Convert guidelines to routes.
    SOLIDWORKS 2026 Auto Route Command
  3. Select the guidelines and click OK.
    Auto Route in SOLIDWORKS 2026
  4. Exit the route sketch and the route subassembly, hide the sketches, and observe the result.
    What's New SOLIDWORKS 2026 Routing Auto Routes
Automatically Scale Tables, Views, and Annotations when Changing Drawing Sheet Size of Flattened Route
When creating flattened drawings of electrical routes, sometimes the default sheet size becomes too crowded with the views, tables, and annotations, and it become necessary to change the sheet format to a larger paper size. In previous versions of SOLIDWORKS, this has been tedious and time-consuming because of the requirement to scale the views, tables, and annotations separately.
In SOLIDWORKS 2026, moving to a larger sheet size is much simpler.
This is currently a D-size sheet, and I would like a bit more room to add additional annotations and give more room for the table, so I will make it into an E-size sheet.
Automatically Scale Tables, Views, and Annotations when Changing Drawing Sheet Size of Flattened Route in SOLIDWORKS 2026
  1. Right-click in the drawing and select Properties.
    SOLIDWORKS 2026 Properties Option
  2. Use the Sheet Properties to change the Sheet Format/Size to E (ANSI) Landscape and Apply Changes. (You may see a message about notes. Click “yes”.)
    SOLIDWORKS Routing 2026 Sheet Properties
  3. Notice that the sheet has much more space to rearrange/resize the tables without needing to change the drawing view.
    Change Drawing Sheet Size in SOLDIWORKS 2026 Routing
That's a wrap for what's new in SOLIDWORKS Routing 2026. Check out the rest of our SOLIDWORKS 2026 What’s New series for more updates across the SOLIDWORKS platform.
More What's New
SOLIDWORKS Simulation 2026 - What's New
SOLIDWORKS 2026 UI/UX, Performance & Imports - What's New
SOLIDWORKS 2026 Parts and Features - What's New
VIEW ALL ARTICLES
About Dennis Barnes
View all posts by Dennis Barnes
