Starting with 2015, SOLIDWORKS PDM uses the SolidNetWork License (SNL) Server to handle PDM licenses, just like SOLIDWORKS network licenses. As a result, companies must install the SNL server when they upgrade to PDM 2015 or later. Because it is a first-time installation of the SNL server, connection problems can pop up once the upgrade is complete.
If you perform an upgrade of SOLIDWORKS PDM from 2014 or earlier and you find that your client computers can’t access the license server even though your licenses have been activated, the problem is likely due to ports in the Windows Firewall that need to be opened. Read on.
In a typical environment, Windows Firewall is active on the server and may also be active on the client computer as well. The SNL server needs to communicate with each PDM client using two ports, typically 25374 and 25375. In both cases, the protocol is TCP.
To ensure that this communication can take place, connection Rules (sometimes called ‘Exceptions’) must be made in the Firewalls. Perform the following step starting with the server first, then do the same on each user machine where the Firewall is active. Here’s a step-by-step using Windows 7:
Opening the ports in this way should allow each PDM client computer to successfully communicate with the PDM server.
Option File - A Great Solution For Managing Your SNL(s)
Changing SOLIDWORKS PDM License Types
Moving the SOLIDWORKS PDM Archive Server Yourself? Start Here
