After a SOLIDWORKS or Windows update, your 3Dconnexion mouse may no longer respond or move inside SOLIDWORKS. This can happen even after trying various fixes, such as unplugging the mouse and then plugging it back in. Here are some tips to help fix this issue.
Follow these steps to reset your 3Dconnexion mouse so it can once again work with SOLIDWORKS:
Once finished, relaunch SOLIDWORKS and verify the 3Dconnexion add-in is enabled. The 3Dconnexion mouse should be functional once again in SOLIDWORKS (along with any other applications compatible with the 3Dconnexion mouse).
If the above solution does not fix the 3Dconnexion and SOLIDWORKS issue, try uninstalling the 3Dconnexion add-in from the affected machine, downloading the newest driver from the 3Dconnexion website, and installing that driver as a replacement.
Downloads for the latest 3Dconnexion drivers can be found here: https://3dconnexion.com/us/drivers/
To do a clean uninstall and reinstall of the 3Dconnexion driver/software, follow the steps listed below. Before starting, first log in with full administrative privileges.
In the off chance that the above suggestions do not resolve the issue with your 3Dconnexion mouse not working with SOLIDWORKS, reach out to the 3Dconnexion support team for further review.
Want to learn more? Check out more tutorials below. Additionally, check out the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
Create Custom Wire Numbers in SOLIDWORKS Electrical 2D
SOLIDWORKS PDM – Create Local Host File Workaround as Temporary Solution
Stuck Borrowed SOLIDWORKS Network License
3DEXPERIENCE SOLIDWORKS Local Cache Management
About Nathan Marsh
Nathan Marsh is a Senior SOLIDWORKS Technical Support Engineer at GoEngineer.
