Copy a Surface in SOLIDWORKS Tutorial
Article by GoEngineer on Aug 26, 2015
In this tutorial, learn how to copy a surface and export it into another part with SOLIDWORKS.
Go to File > Open and open the part that you want to copy the surfaces from, into another part.
Steps to copy a surface in SOLIDWORKS
To demonstrate the process, we will be using this example part.
Copying a Surface in SOLIDWORKS Tutorial
  1. Start by copying the surfaces of the four legs of the stool.
  2. CTRL Select all four stool legs.
    SOLIDWORKS Tutorial Copying Surface
  3. Then go to Insert > Surface > Offset and select it.
    SOLIDWORKS Insert Surface Offset
  4. The Offset Surface dialog box will appear on the left.
    SOLIDWORKS Offset Surface Dialog Box
    1. Notice that it has the surfaces selected in the Offset Parameters.
    2. Also, notice that the default Offset distance is 0.100in
  5. Change the Offset distance to 0.0in.
    SOLIDWORKS Offset Distance
  6. Click the green checkmark.
    1. Notice that there is the Surface Offset1 in the FeatureManager Tree.
      SOLIDWORKS FeatureManager Surface Offset
  7. Save your part.
  8. Start a new part by selecting File > New > Part.
  9. Go to Insert > Part.
    Insert a Part in SOLIDWORKS
  10. Open the Part you just saved.
    How to copy a surface in SOLIDWORKS
    1. Notice the Insert Part dialog box shows up. Check Surface bodies as shown below and click the green checkmark.
      SOLIDWORKS Surface Bodies
  11. Your final result will be the Stool Leg surfaces.
  12. Also, see in the Feature Manager Tree the Part name is shown and your surfaces are now ready to use.
SOLIDWORKS Content Copy Surface
I hope you found this SOLIDWORKS tutorial helpful. Check out more tips and tricks below.
More SOLIDWORKS Tips & Tricks
SOLIDWORKS Wrap Feature Tutorial
Global Variables in SOLIDWORKS Explained
SOLIDWORKS Content: Download Additional Routing Libraries
Easy Way to Link Properties to a SOLIDWORKS Drawing
VIEW ALL SOLIDWORKS TUTORIALS
