Creating Sub Balloons in SOLIDWORKS Inspection Standalone
Article by Ryan Field on Sep 19, 2023
Getting an Inspection drawing set up so that the inspector can clearly interpret it is vital. One way SOLIDWORKS Inspection can help is by creating sub balloons. In this tutorial, we explain how to do so in the Standalone interface.
Creating Rows for Each Instance
When you have a characteristic with multiple instances (e.g., holes or fillets), you may want to call out each one of those instances on the drawing. But, before you can do this, you must have rows for each of those instances on the Characteristics Tab of the Table Manager; either individually or automatically.
SOLIDWORKS Inspection Instance
To do this automatically, upon creation of the characteristic of a dimension called out with a quantity greater than one, an Extraction Project Option can be set to Create For Each Instance. (This can also be turned on and saved in the Project Template).
Extracted Project Options in SOLIDWORKS Inspection
If this setting was unchecked when you created the characteristic, and there is only one row in the Characteristics Tab, you can still add them manually. To do so, select the characteristic, then choose the icon next to the Quantity in the Characteristic Properties. (Quantity must be greater than one.)
SOLIDWORKS Inspection Characteristic Properties
This will add a row for each instance on the Characteristics Tab.
SOLIDWORKS Inspection Standalone Table Manager Characteristics
Alternatively, right-click the Row on the Characteristics Tab and select Grouping > Create for Each Instance.
SOLIDWORKS Inspection Create for Each Instance Option
Create Sub Balloons
Now that you have characteristics with rows for each instance, you can create sub-balloons. Right-click an instance and choose Create and Place Sub balloons.
How to Create and Place Sub balloons in SOLIDWORKS Inspection
Then, when you click anywhere on the drawing, it will create the ‘X’.2 balloon, and the original balloon will become ‘X’.1. If the quantity is greater than two, keep clicking until all the subsequent sub balloons are placed (‘X’.3, ‘X’.4, etc.). Feedback at the cursor lets you know the quantity you are going to create and how many you have left to go in the command.
If the balloons are not exactly where you want them, move them.
Reverse It
If you do not want to have the sub balloons and rows for each instance, remove them. Right-click in one of the rows and choose Grouping > Merge To Single Instance.
Merge to Single Instance SOLIDWORKS Inspection
The sub balloons will then go away, the ‘X’.1 balloon will return to just ‘X’, and all the rows for the additional instances on the Characteristics Tab will also go away.
The quantity in the Characteristic Properties will reflect the total number merged.
This is just one of the many examples of how SOLIDWORKS Inspection can help streamline the creation of inspection documentation. Check out more SOLIDWORKS Inspection tutorials below.
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Inspection Tutorials
How to Add Custom Properties to SOLIDWORKS Inspection Projects
Make SOLIDWORKS Inspection Reports Easier to Read with Conditional Formatting
Working in Tandem: SOLIDWORKS Inspection and SOLIDWORKS PDM
How to Leverage SOLIDWORKS Inspection & SOLIDWORKS PDM Professional
VIEW ALL SOLIDWORKS INSPECTION TUTORIALS
About Ryan Field
Ryan Field is a Sr. Application Engineer at GoEngineer.
View all posts by Ryan Field
