Getting the Total Length of a Bent Pipe in a SOLIDWORKS BOM
Article by Rodolfo Gutierrez on Dec 06, 2016
In this tutorial, learn how to get the total length of a bent pipe in your SOLIDWORKS BOM (Bill of Materials) in just three steps.
Step 1: Create a Global Variable
Chances are you used a Sweep feature to create your pipe part model, hence having a “path” sketch.
  • Edit the sketch and make sure you have a length for the straight segments and any splines. The spline length dimension is only available in SOLIDWORKS 2014 and newer versions.
  • Insert an equation by going to Tools > Equation. In the Name column, under Global Variables, give your global variable a name. I named mine: A.
  • Tab over to the value/equation column and type the equal sign (=) as to start an equation. Then move the equation window enough to where the dimensions are exposed and can be selected. You’ll want to select each with a + in between.
  • Ensure that your global variable evaluates. If it is not evaluating, then the issue lies in the syntax of the equation.
    SOLIDWORKS Getting Total Length of a Bent Pipe in Your BOM
      Step 2: Create a Custom Property
      While still in the pipe part model, create a new custom property by going to File > Properties.
      • Name your custom property. Ensure a new property name.
      • Link the new custom property to the new global variables by selecting it from the list of options in the drop-down menu. In this example, I linked variable A to property total length (keep in mind that this will also be the column header in later steps).
      • Ensure you have an Evaluated Value.
        Getting Total Length of Bent Pipe for Your SOLIDWORKS BOM
      Step 3: Link a new BOM column to the custom property
      Go to the assembly bill of materials and insert a new column by right-clicking a header of an existing column and selecting Insert > Column Right/Left.
      • When prompted to assign properties to the new column, select to link CUSTOM PROPERTY, and for Property Name, select your new custom property. In this example, it is total length.
        Link New BOM Column to the Custom Property in SOLIDWORKS
      • For you to have an evaluated (-) sign in the total length column for the rest of the components in the assembly, you have to create a new custom property for each component.
        SOLIDWORKS BOM Tutorial Get Total Bent Pipe Length
        SOLIDWORKS Tutorial Bent Pipe Length BOM
      That's it! I hope you found this SOLIDWORKS tutorial helpful. If you'd like to learn more about BOMs in particular, check out some of the additional resources listed below.
      More SOLIDWORKS Tutorials
      SOLIDWORKS Tips and Tricks to Modify Your BOM
      Link a Dimension to the BOM with a Custom Property
      Showing Cut List Item Names in a BOM: SOLIDWORKS Tutorial
      BOM Compare: SOLIDWORKS Utilities
      GoEngineer YouTube Video the Bomb of All BOMS The BOMB of All BOM Webinars
      VIEW ALL SOLIDWORKS TUTORIALS
      About Rodolfo Gutierrez
