Sheet Metal is a feature in SOLIDWORKS that allows users to create bend and flat patterns simultaneously. When paired with the option to save files as .dxf for easy laser cutting, SOLIDWORKS becomes the preferred choice for industry leaders. SOLIDWORKS also allows users to create templates. These are starting points for your files, saving you even more time.
One of the advantages of using templates is that they allow you to preselect various settings, such as units and color selections, so you don't have to change them each time you start a new file. Sheet Metal has its own set of settings. One of which is the gauge table.
Whether you work with multiple gauge tables or just one, creating a template with the gauge table already selected can be very beneficial. However, a template that includes a gauge table can be a bit complicated, especially since sheet metal settings require a configured sheet metal feature. Let’s walk through the process of creating a template that incorporates a gauge table.
I hope you found this article explaining how to add gauge table templates in SOLIDWORKS helpful. Check out our tips and tricks below. Additionally, join the GoEngineer Community to participate in discussions, create forum posts, and answer questions from other SOLIDWORKS users.
Want to sharpen your skills? Learn to build stand-alone sheet metal parts and convert conventional parts in our Professional SOLIDWORKS Sheet Metal training course.
SOLIDWORKS Sheet Metal Lofted Bend Manufacturing Methods Bent & Formed
How to Create Sheet Metal Bend Notches in SOLIDWORKS
SOLIDWORKS Sheet Metal Sketched Bend Tutorial
SOLIDWORKS Drawings – Unable to Dimension Sheet Metal Bend Lines
About Palmer Bubb
Palmer Bubb is a Technical Support Engineer and Certified SOLIDWORKS Expert (CSWE). Prior to joining the technical support team in 2021, Palmer designed retail fixtures for major retailers such as Lowes, Publix, Meijer, and Harbor Freight. He graduated from Northern Illinois University with a degree in Mechanical Engineering. Palmer enjoys weightlifting, local coffee shops, book stores, and live music.
