How to Copy SOLIDWORKS Custom Properties to Other Files
Article by GoEngineer on Jan 29, 2021
It is possible to copy every Custom Property in a SOLIDWORKS file to another document. If you are familiar with Microsoft Excel, it will be just like copying and pasting a range of cells. To Copy SOLIDWORKS Custom Properties to other files, follow these steps:
  1. Open the Custom Properties dialog Box:
  2. With the dialog box open, use Windows selection tools to select one, some, or all properties
    1. To select one, click the number on the row of the desired column.
    2. To select some, left-click row numbers while holding down the CTRL key.
    3. To select all, left-click the first row, hold the SHIFT key, and left-click the last row. (See example below)
      SOLIDWORKS Custom Properties Copy to Other Files
  3. Use the Windows keyboard shortcut for copying, CTRL + C
  4. Close the Custom Properties dialog box.
  5. Open the target file
  6. Open its Custom Properties dialog box.
  7. left-click the 1 in the first column
  8. Use the Windows keyboard shortcut for paste, CTRL + V
  9. Done!
I hope you found this quick tip helpful. Learn more tricks in SOLIDWORKS below.
SOLIDWORKS Custom Properties Tab Builder: Step-by-Step Guide
Using SOLIDWORKS Task Scheduler to Create or Modify Custom Properties
Customize Colors in SOLIDWORKS Drawings
Customizing the SOLIDWORKS Hole Callout File
SOLIDWORKS FeatureManager: Hidden/Forgotten Commands
Easy Way to Change the Language in SOLIDWORKS
