Although SOLIDWORKS has an extensive material library, users often need to create custom materials. The ability to add custom materials enables users to calculate an accurate mass or simulation of a part or assembly. The following steps demonstrate the processes to create a new material in SOLIDWORKS.
In a SOLIDWORKS part, materials can be changed by going to the design tree, right-clicking Material, and selecting Edit Material.
In a simulation, materials can be changed without opening the individual part. Simply right-click on the part in the design tree and select Edit Material.
Once the Martial dialogue box is open, scroll to the bottom of the material tree. Right-click on custom material and select New Library, then create a New Category within the Library. This example uses a library called Custom Plastics and a category called Non-Linear Plastics. Click Apply.
New materials can be created by copying and pasting a similar material, or entering the material properties manually. Existing SOLIDWORKS materials cannot be edited. To copy a material, simply click on a material in the existing SOLIDWORKS Library, right-click and select Copy. Right, click in the new category and select Paste. Click Apply.
Select the model type, and enter the values by double-clicking the value box. Click Apply.
Congratulations! You have now successfully created a new material in SOLIDWORKS.
