Document Twisted Pairs Contained in a Cable in SOLIDWORKS Electrical Schematic
 Article by Martin Adams on May 21, 2026
Twisted pairs of conductors within a cable are not uncommon. Twisted pair cabling, however, is a type of cable in which two conductors of a single circuit are twisted together to improve resistance to electromagnetic interference. Documenting this can be challenging. Let’s look at our options in SOLIDWORKS Electrical.
Twisted Pairs Contained in an Electrical Cable
Grouping Pairs of Conductors
When you add a cable with twisted pairs to your cable library in SOLIDWORKS Electrical Schematic, you will notice a Group icon under the Cable cores section of the Cable reference properties.
Group Conductor Pairs in SOLIDWORKS Electrical
This icon will be greyed out until you hold CTRL and select a pair of wires to group. Select the wires that are part of a twisted pair, then select the Group button.
Group Button in SOLIDWORKS Electrical Schematic
The grouped wires will now have the same group information, which will be used in tables, wire labels, symbols, and reports. The following examples are representative of those scenarios.
Note: The following examples use a group number. You can also choose to use a text identifier for better clarity. The text will be used in place of a group number.
 SOLIDWORKS Electrical Schematic Cable Reference Properties
Connector Tables
SOLIDWORKS Electrical Connector Tables
Wire Labels
SOLIDWORKS Electrical Wire Labels
Reports
SOLIDWORKS Electrical Report Manager Twisted Pair Group
Symbols
Document Twisted Parts Contained in a SOLIDWORKS Electrical Schematic Cable
Summary
However you choose to document your twisted pairs within a cable, SOLIDWORKS Electrical Schematic has you covered.
Want to learn more about SOLIDWORKS Electrical? Check out the articles listed below. Additionally, join the GoEngineer Community to create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
SOLIDWORKS Electrical Schematic: Importing Data from the Electrical Content Portal
Create Custom Wire Numbers in SOLIDWORKS Electrical 2D
SOLIDWORKS Electrical 2026 - What's New
Gaining Insight Into the Little ”Tells” of SOLIDWORKS Electrical Schematic
SOLIDWORKS Electrical Schematic: Importing Manufacturer Parts from Local Source
View All SOLIDWORKS Electrical Articles
About Martin Adams
View all posts by Martin Adams
