How to Fade Geometry in SOLIDWORKS Visualize Professional
Article by Zach Brown on May 23, 2022
In this guide, we discuss how to fade geometry in and out within SOLIDWORKS Visualize Professional. When working with assemblies, it can be important to show internal functions. We can utilize the animation functions in Visualize Professional to fade away geometry and reveal internal components.
Getting Started
In this example, we have a layout of a patio with furniture. We will create an animation to fade out the furniture and zoom in on a handrail.
Fading Geometry in SOLIDWORKS Visualize Tutorial
In Visualize, switch the 3D Viewport to Preview Mode. Doing so will allow for a more responsive interaction with the design and place less of a burden on the CPU.
Preview Mode in SOLIDWORKS Visualize
Because we will be working with animations, go to the View menu and choose Show Timeline. This will bring up the timeline at the bottom of the Visualize interface.
Show Timeline Option in SOLIDWORKS Visualize
On the Timeline toolbar, turn off Auto Keyframing so we can manually set up key frames.
Drag the red flag to about 6 seconds on the timeline. Now we are ready to start adding key frames.
Adding Keyframes in SOLIDWORKS Visualize
Creating the Annimation
For the remainder of this tutorial, we will create key frames to set the opacity and camera angles of components along the timeline.
Switch to the Model Tab and hold SHIFT to select all the model groups, then right-click, go to Animation, and click Add Keyframe.
How to Add a Keyframe Animation in SOLIDWORKS Visualize
All the components are added to the timeline. Drag the yellow flag to about 2 seconds.
Create Animation in SOLIDWORKS Visualize Professional
Click on the Patio-1 model and, under the General Tab, make sure the Opacity is set to 1.
Next, right click on the Patio-1 model and add another keyframe. This creates a new keyframe for the patio at 2 seconds with full opacity.
SOLIDWORKS Visualize Professional Fading Geometry Opacity Amount
For the couch model, I will set the opacity to 0, then-right click on the model and add another keyframe. The couch disappears.
Moving the yellow slider from 0 to 2 seconds shows the couch fading out. Also, notice the opacity slider moving from 1 to 0 as the yellow slider moves along the timeline.
Repeat the steps of setting the opacity to zero and creating keyframes for the rest of the furniture.
Opacity Set to Zero in SOLIDWORKS Visualize
For the next phase of the animation, we will zoom in on one of the handrail assemblies and hide all other components.
First, expand the Patio-1 group and add a keyframe for the Parts to Hide model.
Move the yellow flag to about 4 seconds on the timeline, set the opacity of Parts to Hide to zero, then right-click on the model and add a keyframe.
Opacity of Parts to Hide Set to Zero in SOLIDWORKS Visualize
Moving the yellow slider from 2 to 4 seconds will show the patio and remaining handrails fading out completely.
To zoom in on the handrail, switch to the Camera tab, move the yellow slider to about 3 seconds, then right-click on the active camera and add a keyframe.
Camera Tab Add Keyframe Option SOLIDWORKS Visualize Professional
Move the yellow slider to the end of the animation (6 second mark) and hover over the 3D Viewport and use the middle mouse button to zoom into the remaining handrail.
Right-click on the active camera and create the last keyframe. Play the animation to see all the transitions.
How to Fade an Animation in SOLIDWORKS Visualize
To make a change to the time point on one of the keyframes, click on the desired keyframe, then select the arrow beside the timeline to reveal the Keyframe Properties. From there, you can change the Time Point and tweak the Transitions as desired.
SOLIDWORKS Visualize Keyframe Properties
Video Demonstration
Check out our YouTube video for a demonstration of Fading Geometries.
GoEngineer YouTube Video SOLIDWORKS Visualize - Fading Geometry SOLIDWORKS Visualize - Fading Geometry
I hope you found this SOLIDWORKS Visualize tutorial helpful. Check out more tips and tricks listed below.
More SOLIDWORKS Visualize Tutorials
SOLIDWORKS Visualize Appearances and Hardware Utilization
SOLIDWORKS Visualize 2022: New Shadow Catcher, Camera Views, Animations, & More
SOLIDWORKS Visualize Error Unable to Connect to Queue
How to Use SOLIDWORKS Configurations in Visualize
Apply Multiple Appearances in SOLIDWORKS Visualize
VIEW ALL SOLIDWORKS VISUALIZE TUTORIALS
About Zach Brown
View all posts by Zach Brown
