From Hobby to Heavy Duty: Why High-Performance Polymers Matter Now
Article by Bob Renella on Sep 29, 2025
In its infancy, 3D printing was primarily used for prototypes and passion projects. If the end result looked good and held together for a few hours, it passed the test. But times have changed. Engineers now expect printed parts to survive stress, heat, and real-world use. That shift, from hobby to heavy duty, hinges on one factor: better materials.
PLA Days Are Over
If you’ve been around long enough, you’ll remember the slow but exciting sound of a MakerBot Replicator printing a Benchy, layer-by-layer. PLA and ABS were the go-to plastics then. Easy to print, but easy to break. They were fine for looks, but failed under pressure (literally).
If the part was exposed to heat, it warped. If it came into contact with chemicals, it cracked (or melted). Could it last for months? Not a chance. That’s when the industry realized that the 3D printers weren’t the problem. The materials were.
Meet the Workhorses
The rise of industrial 3D printing wasn’t just about hardware; it was about materials that could actually do the job. Let’s take a look at five materials that changed the game:
#1. ULTEM™ FDM Material
Ultem is a far cry from standard filament. ULTEM™ 9085 combines flame resistance, thermal stability, and strength - all in a lightweight package. Aerospace and rail industries love it for a reason: it’s tough, traceable, and qualified.
Ultem 9085 Material Turbine Intake
"ULTEM™ 9085 resin is aerospace grade and possesses documented traceability, which enabled us to certify these parts for flight.” – Chris Botting, (Marshall Aerospace Stratasys Case Study).
#2. Stratasys ToughOne™
PolyJet isn’t just for full color models anymore. ToughOne lets design teams create functional prototypes with impact resistance and mechanical durability. If you’re pushing a design to its limits, this material won’t fall apart on the bench.
Stratasys ToughOne Material
Loctite 3D 3955 Durable 3D Printing Material
#3. LOCTITE® 3D 3955
UV-curable and flame-retardant, this resin is built for demanding parts in transportation, aerospace, and consumer electronics. Origin’s P3 platform gives you tight tolerances and crisp detail, without compromise.
#4. Somos® PerFORM
Designed for high-heat, high-stress applications, PerFORM is ideal for tooling, wind tunnel models, or any part needing stiffness and detail. It prints fast on the Neo series, and its ceramic-filled formulation gives it a real edge in thermal and mechanical performance.
Somos PerFORM SLA 3D Printing Material
#5. Antero™ 800NA
Antero 800NA (PEKK) brings high heat resistance, chemical resistance, and low outgassing, all critical for aerospace and defense. Combined with the massive F900 build envelope, this unlocks serious potential for end-use parts. Watch the Antero use case at Marshall Aerospace to see how they're using it in certified flight hardware.
Antero 800 NA 3D Printing Material
These materials may not be flashy, but they’re functional.
Why It Matters Right Now
Industries aren’t printing parts just because they can; they’re doing it to solve real problems. Supply chains are tighter. Product timelines are shorter. And expectations are higher. Jacob Allenbaugh, a manufacturing engineer at Piper Aircraft, explains, “I can program an FDM part in 10 minutes while a typical CNC program takes four hours to write. The FDM 3D Production System can be much faster than a CNC machine and does not require an operator in attendance.”
High-performance polymers enable engineers to reduce costs and eliminate lengthy lead times. When you dial in your setup, you can print a part that ships the same week.
FDM 3D Printed Composite Layup Tool
3D printing this composite layup tool saved 75% in time, cost, and weight
Brian Kaplun of Lockheed Martin Space puts it best, “We’ve been able to see orders of magnitude savings both in cost and schedule on all of these parts because the part builds are very consistent, the material properties are well understood, and the build parameters are becoming better understood.” (Source: Transitioning to Production Applications Using Additive Manufacturing)
Speed is good, but control is better. With additive manufacturing, you're not waiting for outside vendors or hoping supply chains hold up. You build what you need, when you need it.
But, let’s be real. Printing with these polymers is hard.
You need high-temperature, precise, and reliable, high-performance machines. And post-processing isn’t optional; it’s part of the workflow. But the payoff is huge.
The Takeaway
Additive Manufacturing has grown up. It’s beyond the early days of printing just to tinker. Production-ready, certifiable, and built to last, that’s what the right materials deliver.
As Mitchell Weatherly at Sheppard Air Force Base put it, “Because most of our projects are either one of a kind or very low volume, conventional methods become very expensive.” (Source: Stratasys Case Study "FDM direct digital manufacturing saves $800,000 and development time")
3D printing with advanced materials makes those projects not only possible, but practical.
So, the question is: are you still treating 3D printing like a hobby, or are you ready to build parts that last?
Contact our sales team to learn how advanced 3D printing technologies can transform your production capabilities.
3D Printing as a Service
GoEngineer offers comprehensive 3D printing services across multiple U.S. labs, equipped with cutting-edge Stratasys FDM, PolyJet, Stereolithography, P3, and SAF technologies for 3D printed prototypes or production parts. Request your quote online today!
Antero 840CN03 Deep Dive: Strengths, Applications, Limitations & More
DyeMansion Powershot C Consumables Stream: How It Works
Stratasys Separator DM for Acrylic Orthodontic Appliances
FDM Post-Processing: Oryx sca1200ht for Soluble Support Removal
How 3D Printing is Helping Manufacturers Fight Back Against Tariffs
VIEW ALL 3D PRINTING ARTICLES
About Bob Renella
Bob is a Manufacturing Solutions Application Engineer Manager at GoEngineer.
View all posts by Bob Renella
