How to Use the SOLIDWORKS Simulation Probe Tool
Article by Tashayla Openshaw on Oct 12, 2023
After solving a study in SOLIDWORKS Simulation, exact numerical values of the result plot can be obtained from specific faces or nodes in the model using the Probe feature for post-processing. This article demonstrates how to use the Probe tool in SOLIDWORKS Simulation to see results on specific nodes or on particular faces/entities.
Probe Tool Location
Once the study results have populated, any of the results plots can be probed to find wanted values. To start the process, right-click on the plot and select Probe.
SOLIDWORKS Simulation Probe Feature Location
Probe Result Options
The Probe Results menu displays four options: At location, From sensors, On selected entities, and At node number.
SOLIDWORKS Simulation Probe Result Options
Results and Summary
After choosing the wanted selections, the Results section displays a list of nodes, their corresponding stress values, and their X, Y, and Z locations.
Under Summary is a list of the Sum, Average, Max, Min, and RMS of the values.
Below are examples of each.
  • At location – Select wanted nodes/points on the model in the design space.
    At Location SOLIDWORKS Simulation Probe Result Option
  • From sensors – Select sensors from the Sensor List (this option is greyed out until sensors are added). Sensors can be added after the study has been run. Then, when you probe the wanted result plot, the option is available and the probe results can be seen from the sensor.
    From Sensors SOLIDWORKS Simulation Probe Result Option
  • On selected entities – Select any faces, edges, or vertices, then select Update.
    On Selected Entities SOLIDWORKS Simulation Probe Result Option
  • At node number – Input the number of the wanted node and select the Probe Result icon.
    At Node Number SOLIDWORKS Simulation Probe Result Option
report-options
There are also a few reporting options for these probed results.
SOLIDWORKS Simulation Probe Feature Report Options
  • Save As Sensor allows us to select any of the nodes listed under Results to create a sensor list.
  • Save saves the probe results to a .csv file.
  • Plot takes the results and generates a 2D graph that can be saved.
  • Response is available for transient studies only and will graph the results vs steps.
  • Capture Image takes a picture of the model in the design space. These can then be saved as .png, .jpg, or .bmp files.
  • Copy to Clipboard will copy the results, to be pasted elsewhere.
Annotation Options
Select what annotations can be seen in the design space for the probed results.
SOLIDWORKS Simulation Probe Feature Annotations Option List
The following annotation options can be turned on or off:
  • Show Node/Element Number
  • Show X, Y, Z Location
  • Show Value
I hope you found this SOLIDWORKS Simulation tutorial helpful. Sharpen your skills even more by enrolling in an official SOLIDWORKS Simulation training course.
Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Simulation Tutorials
SOLIDWORKS Simulation vs Abaqus: When Should You Upgrade?
SOLIDWORKS Simulation Mesh Convergence in Frequency Analysis
What is Topology Optimization - SOLIDWORKS Simulation
SOLIDWORKS Simulation Nonlinear Material Model Type Setup
SOLIDWORKS Simulation Variable Amplitude Time History Fatigue Tool Tutorial
About Tashayla Openshaw
