When applying a Chamfer (or Fillet) to an edge in SOLIDWORKS that is tangent to another edge, the software will partially extend the Chamfer/Fillet into the tangent edge as well. (Figure 1)
(Figure 1)
With the release of SOLIDWORKS 2019, users can create Partial Chamfers and Fillets, allowing us to control the length of the Chamfer/Fillet from each end of the edge. (Figure 2)
(Figure 2)
On the Feature Toolbar, click the Fillet icon or click the drop-down arrow next to the Fillet command and click Chamfer. In the Chamfer/Fillet PropertyManager, click Partial Edge Parameters.
Once you have added a Chamfer or Fillet to an edge and have engaged Partial Edge Parameters, you can set the Distance Offset value for the Start and End conditions. Once you have adjusted the values for one edge, you can highlight another edge and repeat the process.
(Figure 3)
The Partial Edge Parameter option is only available with Offset Face for Chamfer Type, and Constant Size for Fillet Type. Also, any edge that completes a closed-loop (regardless of whether Tangent Propagation is unchecked) cannot be used for Partial Edge Parameter; the options will become grayed out. (Figure 6)
(Figure 6)
How to Minimize Sink Marks in Ribs in SOLIDWORKS Plastics
SOLIDWORKS FeatureWorks: Automatic vs Interactive Recognition
SOLIDWORKS Simulation Edge Weld Connector: Types, Sizing, and More
About Zach Brown
