SOLIDWORKS Purge Unused Features Explained
Article by Lauren McGarry on Dec 28, 2017
Purge Unused Features is a function in SOLIDWORKS introduced in 2016 that allows the user to delete all features and components that are suppressed in all configurations simultaneously. It can be reached by right-clicking the name of a part or assembly in the FeatureManager tree. Purge Unused Features has potential uses in a number of different situations, including deleting a part or component from all configurations and cleaning up designs that have gone through a number of revisions.
In an assembly, you can purge suppressed components, suppressed assembly features, and sketches and reference geometry made in the assembly that do not have any child references. To purge unused reference geometry and features created in a specific component, you have to open up the part itself.
Below is an example assembly. The items we want to delete are Square (Unused), Unused Triangle Sketch, and Unused Chamfer Feature.
Purge Unused Features is an option in the dropdown menu that appears when you right mouse click the name of the top-level assembly in the FeatureManager Design Tree.
SOLIDWORKS Purge Unused Features Location
When selected, a Purge Unused Features window will open listing all the items SOLIDWORKS has identified as candidates for deletion. You can select from this list or check or uncheck all. Initially, all suppressed components and features will be checked and unused sketches and reference geometry will be unchecked.
 SOLIDWORKS Purge Unused Features Window
After hitting OK a Confirm Delete window appears.
Confirm Delete Dialog Box in SOLIDWORKS
An individual Confirm Delete window pops up for every item selected to be purged in order to avoid the accidental deletion of items the user wants to keep.
Purge Unused Feature Example in SOLIDWORKS
Picking the Undo icon reverses the whole Purge Unused Features operation.
I hope you found this tutorial helpful. For more SOLIDWORKS tips and tricks, check out our YouTube channel, or the articles listed below.
More SOLIDWORKS Tutorials
Fix SOLIDWORKS Error: The Source Folder is Not Versioned Properly
SOLIDWORKS Dialog Box Off Screen Solutions
How to Use Layers in SOLIDWORKS Drawings
SOLIDWORKS Pipe Route Overview
VIEW ALL SOLIDWORKS TUTORIALS
About Lauren McGarry
