When searching for documents within SOLIDWORKS, the software references a list of search paths, located in System Options > File Locations > Search Path. In addition to the defaults, you can easily add additional search paths. Unfortunately, it's not always so easy to remove them. This article explains how to add and remove stubborn search paths in SOLIDWORKS.
To add a new search path, go to SOLIDWORKS Options > System Options > File Locations > Search Paths.
Click Add, browse to a folder, and click Select Folder (the same process as adding any file location).
After you click OK in System Options, User Account Control might display a message like this:
This is SOLIDWORKS helpfully adding this new search path to Windows' indexing list. Click Yes.
If you need to remove a file location from System Options, the process is similar and straightforward...except for Search Paths. If you try to delete a search path, it disappears from the list as you'd expect.
But if you open System Options again later, you may find that it's still there.
This is due to SOLIDWORKS not automatically removing that path from the Windows indexing list.
To remove a stubborn search path from SOLIDWORKS, you'll need to make a change to your Windows indexing options. Find this in the Windows Control Panel by searching in the Start menu.
Once open, click the Modify button and uncheck the folder you wish to remove.
After clicking OK, you'll see the folder has been removed from the indexing options.
If you return to System Options > File Locations in SOLIDWORKS, you'll notice the folder has been removed from the Search Paths list.
I hope you found these steps helpful. Check out more tutorials below. Additionally, check out the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
Ballooning Subassemblies in a SOLIDWORKS Drawing
Why Your SOLIDWORKS Drawing Balloons Have Question Marks (?) or Asterisks (*)
About Matthew Kusz
