The Remote Solver in SOLIDWORKS Flow Simulation is used to run flow analyses on a remote computer connected to the network.
You can see the general hardware and system requirements here.
Under Tools > Flow Simulation > Tools, Options > Remote Solver, set TCP port and directory for remote solver’s temporary files (Fig. 1).
Ensure TCP port inbound/outbound settings are open through the firewall.
Use ping [port number] or Telnet test to confirm a connection.
Figure 1. Step (2.1) – Set the inbound/outbound port number for remote solving.
Figure 2. Step (3.1) – Run command from Flow Simulation. Note “Run At” chooses which computer projects solves on, and “Use” defines how many cores will be used.
Figure 3. Step (3.2) – Browse to the remote computer.
Figure 4. Step (3.3) – Ensure “Remote Solver for Flow Simulation 20XX” is “Started”.
When the remote solver is in use:
Standard Flow Simulation functionality allows for a maximum of two simultaneous runs per license. If we own one SOLIDWORKS Flow Simulation license, we can solve two projects simultaneously on the remote machine. If we have two SOLIDWORKS Flow Simulation licenses, standard functionality allows for four projects to be run simultaneously on the remote machine.
Running multiple projects on a single computer can cause slower solve times due to hardware limitations. Below, we will provide a benchmark for effects on solve time due to simultaneously running projects. For further benchmark data for solve time on single projects, please review the GoEngineer blog SOLIDWORKS Flow Simulation: How Many CPU Cores Do You Need? and the Dassault Systèmes Knowledge Base article “Usage of multiple CPUs and influence on solution time” QA Article QA00000109363. (Login required for access.)
Two SOLIDWORKS Flow Simulation Tutorial files were used for benchmark testing: C3 – Non-Newtonian, and B3 – Heat Exchanger.
The default location of the
Each fileset was adjusted to produce larger solve times.
Example file B3 – Heat Exchanger is modified in three ways from its default.
The total number of cells after modification is 456,692.
Figure 5. B3 – Heat Exchanger example file, CAD modifications include additional pipe bends and fins within the heat exchanger.
Figure 6. C3 – Non-Newtonian, global mesh adjusted to “Level 4” and Local Mesh with Level 3 refinement at fluid/solid boundary applied to walls.
Two separate machines using their own SOLIDWORKS Flow Simulation licenses submitted jobs to a remote machine; specifics are available in Figure 7.
| Model | CPU Type | No. of Cores | Base/Boost Freq. (GHz) | RAM Capacity (GB) RAM Speed (MHz) |
| Boxx Apexx T4 | AMD Ryzen Threadripper Pro 5965WX | 24 | 3.8/4.5 | 128 DDR4-3200 |
Figure 7. Workstation specifications used for benchmark testing.
Local Machine 1 submitted two copies of B3 – Heat Exchanger, and Local Machine 2 submitted two copies of C3 – Non-Newtonian Fluid to the remote machine, for a total of four projects solving simultaneously. Baseline data was produced by projects submitted alone.
| Time to Solves (s) | |||
| Single Project | Simultaneous Solve | Effect on Solve Time | |
| B3 - Submitted from Machine 1 | 174 | 418 | 2.4x |
| B3 - Submitted from Machine 1 | 178 | 424 | |
| C3 - Submitted from Machine 2 | 136 | 411 | 3.0 x |
| C3 - Submitted from Machine 2 | 140 | 412 | |
Figure 8. Simultaneous solves vs individual solves on remote machine, and the effect on solve time.
For simultaneous solves, all four projects pushed to the remote machine and began to calculate within ten seconds.
Figure 10. Task Manager as seen on the remote machine. Four instances of “efdsolver.exe” are running simultaneously. Picture taken shortly after project submission, so RAM usage has not significantly increased.
For those looking to use a remote machine in similar capacities, a few conclusions can be drawn:
If further computing power is necessary, cloud computing is available for 3DEXPERIENCE Fluid Dynamics, a CFD tool of similar functional capability within the 3DEXPERIENCE platform.
Contact GoEngineer if your team is interested in this possible solution.
Summary
We at GoEngineer want to make this process easy for our customers. If you require further explanation or feel your remote solver fails to work due to another unknown issue, please contact your local Value Added Reseller (VAR) or our Technical Support Team.
Editor's Note: This article was originally published in June 2017 and has been updated for accuracy and comprehensiveness.
SOLIDWORKS Flow Simulation 2026 - What's New
SOLIDWORKS Flow Simulation Pickup Truck Tailgate Drag Analysis
SOLIDWORKS Flow Simulation Semi-Truck Drafting and Drag Impacts
Testing Aquarium Filters Using SOLIDWORKS Flow Simulation
About Shivani Patel
Shivani has a background in aerospace engineering, and is the Engineering Manager for southern Texas. She has the Elite certification in SOLIDWORKS and is happy to jump into anything in the SOLIDWORKS licenses. Her main specialty is Simulation - and has spent the past 6 years digging into the Motion Analysis, FEA and CFD programs and supporting many of our oil and gas customers in the south.
