Resolve .err Files When Saving STEP Files in SOLIDWORKS
 Article by Dylan Funk on Aug 12, 2026
Neutral formats like STEP are great for collaborating with other designers who use different CAD software. But sometimes, opening or saving a STEP file doesn't go as planned. If you've ever had a file fail to save as STEP and generate a .err file instead, you're in the right place. This article explains a tool that can be used to track down and resolve geometry issues that prevent SOLIDWORKS from creating a STEP file.
Troubleshooting
  1. Check if a .err file appears in the folder you are trying to save the STEP to. If a STEP file also appears, you may find that it doesn't open in SOLIDWORKS.
  2. Import Diagnostics can be run on the Imported feature in the FeatureManager Design Tree (and may open automatically whenever a bad STEP file is opened), but it can be a slow process and won't work at all if features have already been added.
    SOLIDWORKS Import Diagnostics Tool
  3. The most efficient and reliable way is to use the Check command in the Evaluate tab of the CommandManager.
    Check Feature On SOLIDWORKS Evaluate Tab
  4. Run the check. The Result List will display any issues with the geometry. Clicking on a result will take you to that specific area of the model.
    SOLIDWORKS Check Entity Results List
  5. I recommend going through each result one by one, either suppressing bodies (in the case of a multibody part or assembly) or fixing the geometry. Recheck after each attempt, and/or retry saving until saving does not produce a .err file. In my experience, it's not necessary to resolve all of the geometry errors in order to successfully save the file.
Want to learn more about SOLIDWORKS? Check out additional tutorials and tips below. Additionally, join the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
Resolve SOLIDWORKS Imported STEP File Error: Encountered Invalid Record Index
How to Open Future Version Files in SOLIDWORKS
How to Create a Spring That Will Expand and Compress in a SOLIDWORKS Assembly
Replace a SOLIDWORKS Sketch Entity Without Rebuild Errors
View All Articles
About Dylan Funk
Dylan Funk is a Technical Support Engineer at GoEngineer.
View all posts by Dylan Funk
