SOLIDWORKS Dimensions Dialog Box Options
Article by GoEngineer on Apr 06, 2023
The Dimensions Dialog Box is an incredibly useful tool within SOLIDWORKS. Inside this little box are numerous options and tools that are often overlooked. In this guide, we will go over the different tools/options found within the Dimensions Dialog Box.
What is the Dimensions Dialog Box?
If we draw a line and add a dimension to this line, the Dimension Dialog Box automatically appears, allowing the dimension to be edited. If we already have a line and a dimension in place, we can access the Dimension Dialogue Box by double-clicking on the dimension.
The Dimensions Dialog Box houses many different features that help to edit the dimension or provide options for how the dimension can be used.
Features of the Dimensions Dialog Box
Dimension Value
The primary function of the dialog is the dimension being displayed; we can edit this value to be whatever we want. Once the Dimension Dialog Box is exited, the dimension will update to the newly inputted value.
Dimension Value SOLIDWORKS Dimensions Dialog Box
Spin Box
The Spin Box is the two arrows pointing up and down to the right of the Dimension Value. By clicking the arrows, the Dimension Value changes based on the increment set in the Options.
Spin Box SOLIDWORKS Dimensions Dialog Box
Set the Spin Box increments (as either English or Metric units) in the System Options by going to Spin Box Increments. Whenever the increment is changed, it simply adds the new increment value to the list of available increments.
SOLIDWORKS Spin Box Increments
Reset Spin Increment Value
To switch the Spin Box increment value, simply click the button (step 1 below). This will open the list of Spin Box Increment Values (step 2) that we have input in the settings. We can now quickly toggle between the different values in the list.
Reset Spin Increment Value SOLIDWORKS
Rebuild Button
The Rebuild Button allows us to update the dimension to the current Dimension Value without dismissing the Dimension Dialog Box.
To change the Dimension Value and continue working in the Dimension Dialog Box, click ENTER. The dimension will update, but the box will be dismissed automatically. The Rebuild Button updates the dimensions, but does not dismiss the box, allowing us to continue our work.
Rebuild Button SOLIDWORKS Dimensions Dialog Box
Reverse Sense of the Dimension
This button reverses the sense of the Dimension from positive or negative.
Reverse Sense of the Dimension SOLIDWORKS
Dimension Name
This box indicates the Dimension Name. We can edit the name of the dimension to something more recognizable and use the Dimension Name when creating Custom Properties or Equations.
Dimension Name SOLIDWORKS Dimensions Dialog Box
Notice how when we edit the Dimension Name, only the first half changes. The @Sketch1 remains. The @Sketch1 indicates which sketch the dimension is located in. If we edit the name of Sketch1 in the FeatureManager design tree, the name in the dimension will update as well.
Mark Dimension to be Imported into Drawing
By default, this option is turned on. While on, the dimensions can be directly imported into a drawing.
Thumbwheel
Mark Dimension to be Imported into Drawing in SOLIDWORKS
Below the Dimension Value is a Thumbwheel. We can click and drag the wheel to the right or the left to increase or decrease the Dimension Value by the Spin Box Increments.
Thumbwheel SOLIDWORKS Dimensions Dialog Box
The Dimension Dialog Box provides many useful features and options. For more information on this topic, check out this YouTube video.
Check out more SOLIDWORKS tips and tricks below.
GoEngineer Community   Join the GoEngineer Community!
More SOLIDWORKS Tutorials
SOLIDWORKS Magnetic Mates Explained
SOLIDWORKS Tutorial: Edit, Create, & Convert Style Splines
Breadcrumbs in SOLIDWORKS Explained
SOLIDWORKS Weldments: Corners, Gussets, & Bounding Box
SOLIDWORKS Top-Down Assembly Modeling Quick Tip
VIEW ALL SOLIDWORKS TUTORIALS
