In SOLIDWORKS, Direct Editing tools provide the flexibility to modify geometry that does not contain model features, such as an imported STEP, Parasolid, or IGES file. In this guide, we will look at some Direct Editing tools such as Move and Delete Face.
To turn on the Direct Editing tab, right-click anywhere on the CommandManager, go to Tabs, then select Direct Editing.
In the example below, we have an imported Parasolid with no features to edit. We need to lengthen the body in the Y-direction by 5mm. We can use the Move Face command to accomplish this.
On the Direct Editing tab, choose Move Face, then select Translate. For the faces to select, here we'll choose the bottom and filleted face of the base. Under Parameters, choose a Blind end condition, select the top plane for the direction reference, then key in 5mm for length and click OK.
Now, we need to increase the diameter of the base just a bit. We can also use Move Face to accomplish this. For this example, we will use the Offset option.Select the cylindrical face, key in a length of 3mm and click OK.
This process removes the fillets from the cylinder edges. We can add fillets or chamfers back in later.
Suppose we want to remove the remaining fillet and add chamfers to the edges. To remove the fillet, use the Delete Face command on the Directing Editing tab. Under Selections, choose the fillet face. Under Options, select Delete and Patch and click OK.
The Delete and Patch option resulted in the filleted face being removed and the edges brought together. The Chamfer command is also on the Directing Editing tab. We’ll engage the command and select the edges, key in a value of 3mm, and click OK.
We have now completed our design changes using Direct Editing tools in SOLIDWORKS. I hope you found this tutorial helpful. Check out more tips and tricks listed below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
Learn more about Direct Editing tools, advanced part modeling, and assembly modeling capabilities by enrolling in the SOLIDWORKS Advanced Bundle training course. Both online and in-person classes are available.
SOLIDWORKS Autotrace Tool Tutorial
3 SOLIDWORKS Surfacing Tools to Try
Using the Move/Copy Body Feature in SOLIDWORKS
Why SOLIDWORKS Mates Can Cause Slow Assemblies
About Zach Brown
