When upgrading SOLIDWORKS, the Hole Wizard tables and Hole Callout features may be pointing to the wrong location in the Program Files folder. This article gives a step by step guide to checking and fixing the Hole Callout file locations.
Open the System Options.
Go to file locations.
In the drop down menu, go to Hole Callout Format File. Make sure that the directory is C:\Program Files\Solidworks Corp\Solidworks\lang\english
In the drop down menu, go to Hole Table Templates. Make sure that the directory is C:\Program Files\Solidworks Corp\Solidworks\lang\english
Most of the time, checking the file locations will resolve the issue. However, if the issue is still not resolved, the files may be missing in the Program Files folder. If the files are missing, running a repair should resolve the issue.
I hope you found this article helpful. For more SOLIDWORKS tutorials, check out the links below.
SOLIDWORKS Hole Table Callout Options
SOLIDWORKS Toolbox Default Search Location Option
