In SOLIDWORKS, Multiple Mates is a useful shortcut that can save a bit of time when making several mates to a single reference. Whether there is a need to align pieces of a collapsing telescope or syringe, or to make a surface on multiple parts coincident to each other, Multiple Mates streamlines the process of adding those mates. And like many tools within SOLIDWORKS, it is intuitive and user-friendly.
Multiple Mates can be found in the Mates tool in an assembly. In the Mate PropertyManager menu, select the SmartMates button to activate it.
The first selection is the reference that the rest of the references selected will be mated to. From there, selecting additional references will add the appropriate mate to that reference.
Occasionally, the mate will be aligned incorrectly. If noticed right away, selecting the alignment buttons will realign that mate, but selecting the mate later and flipping alignment will work just as well.
If the selections are confirmed, Multiple Mates will add each of those mates which can be found again in the Mates folder. However, in this instance, we will want to come back to this set of mates and edit them all together again in the Multiple Mates selection window. To make this simple to do as well as cleaning up the mate folder, the Create multi-mate folder option will be selected.
Now when we confirm these mates, a subfolder in our Mates folder has been added that contains each of these associated mates.
An additional option exists for dimension mates that links the value of each of the dimensions, so they are all the same value. This is located just below the Create multi-mate folder option.
After confirming each of the references that Multiple Mates will add, the general form of the assembly has taken shape and the remaining mates can be added in short order.
I hope you found this SOLIDWORKS quick tip describing Multiple Mates helpful. Check out more tutorials below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
Want to take your SOLIDWORKS skills to the next level? Get enrolled in the official SOLIDWORKS Advanced training course. This course provides instruction on advanced features and capabilities in SOLIDWORKS. Advanced Part Modeling teaches you how to use multi‐body solids, sweeping, and lofting features, and the more advanced shaping capabilities of SOLIDWORKS. Assembly Modeling teaches how to maximize your use of the assembly modeling capabilities of SOLIDWORKS. Both online and in-person classes are available.
Introduction to SOLIDWORKS Mates: Standard, Advanced, & Mechanical
SOLIDWORKS Magnetic Mates Explained
Why SOLIDWORKS Mates Can Cause Slow Assemblies
Using SOLIDWORKS Copy with Mates
SOLIDWORKS Mate Controller Explained
About Adam Lundgren
Adam is an Applications Engineer based out of GoEningeer's headquarters in Salt Lake City, Utah. He has a BSME from the University of Utah, is a certified SOLIDWORKS Expert, and has several years of SOLIDWORKS experience.
