In SOLIDWORKS, tables are used to annotate drawings and assemblies. Their appearance can be driven by a company standard, personal preference, or to clarify information. A table template helps maintain consistency and avoid customizing tables for each use. Here, we will take a look at the tools available and how to use a customized table template in SOLIDWORKS.
Except for Design Tables and the General Tolerance Tables, a template can be defined for every table.
The template is the table layout. It contains headings and formatting, but not actual table contents. The template only stores what belongs in the columns.
The table PropertyManager remembers the last used template.
There is one notable exception regarding the Bill of Materials. The supplied template, bom-standard.sldbomtbt, returns as the default template each time a Bill of Materials table is created unless it is renamed. This is intended behavior and no setting exists to change that. To have the PropertyManager remember the last used template, rename the bom-standard.sldbomtbt to another name. From there, the last used table template will be the default.
Table templates are stored in the path set in the file location options; meaning that template locations can be organized and stored based on personal preference. Some users prefer to have them all in the same location, while others would rather have a distributed scheme with multiple folders.
To update the folder locations, in SOLIDWORKS, click Options
> File Locations.
Under Show folders for, select:
Click Add, browse to a folder, and click OK. An unused path can also be deleted here.
To create a custom table template:
When you insert a table using a supplied template and select the table or a portion of it, you will see a formatting toolbar appear. This is like the built-in formatting toolbar. (Shown for comparison)
A key difference is that SOLIDWORKS automatically selects the button for using the default document font.
When inserting a table using a supplied template and selecting the table or a portion of it, a formatting toolbar will appear. This is like the built-in formatting toolbar (shown for comparison). A key difference is that SOLIDWORKS automatically selects the button for using the default document font.
This sets the text format of the table to the settings of the document defined in the drafting standard.
Turning the document font selection off in the toolbar displays the font settings in the toolbar.
The available options depend on the type of table being edited, the cursor position when opening the toolbar, and the method used to open the toolbar.
Click a table cell, row, or column, and this toolbar will appear:
Double-click a table cell, row, or column to see this toolbar instead:
By default, the software places the table editing toolbar above the upper-left corner of the table. While you can drag a toolbar to reposition it, the toolbar remains in position as long as you’re editing the table.
Use the table cell, row, or column toolbars to format Bill of Materials, Hole Tables, Revision Tables, Weld Tables, or Weldment Cut Lists.
After customizing a table, remember to save it for use in other documents.
Select these options when opening the toolbar by double-clicking once in a table cell, row, or column:
When inserting a table, under Table Template in the PropertyManager, click Open table template
In the Select Template dialog box, browse to a template for this table type, and click Open.
Note the SOLIDWORKS document option for inserted table behavior.
Use template settings: Overrides a table's Document Properties with the settings of an imported template.
When selected:
When cleared:
If you encounter strange behavior with table fonts, check this setting. It is a part of the Document Properties and will be initially set by the document template. If needed, edit the template to adjust the setting going forward.
I hope you found this tutorial for SOLIDWORKS table templates helpful. Check out more SOLIDWORKS tips and tricks listed below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
Want to take your SOLIDWORKS skills to the next level? Enroll in the official SOLIDWORKS Drawings training course. Both online and in-person classes are available.
SOLIDWORKS Design Tables Made Easy
Use SOLIDWORKS Indent Feature in an Assembly
SOLIDWORKS Configuration Publisher: Create Configuration Tables
SOLIDWORKS Indent Cut vs Combine/Subtract
About Martin Adams
