Why Your SOLIDWORKS Drawing Balloons Have Question Marks (?) or Asterisks (*)
 Article by Dylan Funk on Feb 04, 2026
Have you ever been working with a drawing in SOLIDWORKS and noticed the balloons showing a yellow question mark (?) or asterisk (*)? There are a few reasons for this, but this blog will cover the most common causes for why these appear in your BOM balloons.
Why Is There a Question Mark (?) in My Balloon?
More often than not, a question mark "?" balloon means it is no longer connected to a part. Sometimes, the leader can become disconnected, and you will need to reconnect this leader so the balloon can become active again.
To do this, click on the "?" balloon to expand the options on the left, click More Properties, then select a leader style.
SOLIDWORKS Leader Styles
Click and drag the balloon around. You should now have a leader attached for connecting to the correct model component.
Why Is There a Question Mark (?) in My SOLIDWORKS Balloon?
Click the endpoint of the balloon and connect it to a part geometry. You will notice that there will be two options for the end condition of the leader. Grabbing a proper edge will result in the arrow head, while dropping the leader onto a face will result in a circular end condition. Either one will still pull the correct BOM number, but I recommend the arrow end condition.
Arrow vs Circular End Conditions in SOLIDWORKS
Now that you have the balloon connected to the part geometry, the question mark should go away.
Why Is There an Asterisk (*) in My Balloon?
When an asterisk "*" appears in a balloon, it's because the current configuration selected for the BOM does not match the drawing view that the balloons are placed on.
For instance, the image below currently has the BOM and the drawing view configurations matching.
Matching SOLIDWORKS BOM and Drawing View Configuration
If I change the BOM configuration to the one I made with the hardware removed, notice what happens.
Both of the balloons that had been attached to the hardware now appear with an asterisk. This happens, despite the hardware being visible, because the balloons reference the BOM configuration, not the drawing view configuration.
Why Is There an Asterisk (*) in My SOLIDWORKS Balloon?
If I were to change the configuration of the drawing view to match the BOM, those balloons would disappear. So to ensure the asterisk is removed, always verify that the drawing view and the Bill of Materials use matching configurations.
 Default Drawing View SOLIDWORKS Configuration
Another reason the “*” may appear is when the drawing view has the balloons pointing to a different table. For example, if I right-click on the drawing view and choose Properties, I can change which Bill of Materials that the view chooses to link the balloons to.
SOLIDWORKS Balloon Drawing View Properties
For instance, if I switch the Drawing View Properties to reference "Bill of Materials2" (which is a BOM I created with no hardware), I will again see an asterisk on those balloons that are pointing to hardware no longer appearing on the associated BOM.
SOLIDWORKS Balloons in Drawing View Properties
SOLIDWORKS Bill of Materials with No Hardware
Hopefully, these examples help solve the “?” and “*” issues when making your SOLIDWORKS drawings.
Want to learn more? Check out more tutorials below. Additionally, check out the GoEngineer Community, where you can create forum posts, enter design contests, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Tutorials
SOLIDWORKS Custom Property for Monitoring Surface Area
VIEW ALL SOLIDWORKS TUTORIALS
About Dylan Funk
Dylan Funk is a Technical Support Engineer at GoEngineer.
View all posts by Dylan Funk
