Some SOLIDWORKS users are experiencing an error stating: The current computer identifier does not match... when activating SOLIDWORKS 2024 on a machine that has previous versions of the software installed.
This error is due to an update to the FLEXnet licensing service included with SOLIDWORKS 2024. The FLEXnet licensing service runs in the background (and is used with all versions of SOLIDWORKS) to handle the activation and deactivation of a license through the use of a Computer ID.
With the update, changes to the FLEXnet service are causing a new Computer ID to be generated for the computer performing the activation. This is causing a failure where the Computer ID listed on the SOLIDWORKS Licensing server side is different from the current ID on the computer, resulting in an error message during the activation process.
So, how do we prevent this error?
(These steps are also available in this guide: SolidNetWork License Administrator Server Upgrade)
Perform the following steps before installing SOLIDWORKS 2024:
If you have already upgraded and are experiencing this error, a Technical Support Engineer can help. If you're a GoEngineer customer, email our support team at Support@goengineer.com or call 888-559-6167. Knowing your serial number and computer name will help resolve this issue in a timely manner.
How to Get Rid of SOLIDWORKS Resource Monitor Messages
Why Am I No Longer Able to Access SOLIDWORKS Sites?
Temporary SOLIDWORKS Certification Vouchers Procedure
How to Create a SOLIDWORKS Rx in SOLIDWORKS, Electrical, and Composer
About Nathen Blas
